| Problems/Service/Repairs If you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post! |
#1 | ||
Engine Power Reduced Light on
2007 Chevrolet HHR 1LT -Sport Red Metallic- 2.4L engine, Bright Chrome Appearance Package, Running Boards, Chevrolet Windshield Decal, Ruby Red IPCW LED Tail Lights, Draw-Tite Hitch, Ebony Interior |
#2 |
First thing is to test the battery and if it fails replace it before any other testing is done. a bad battery that falls below 9 volts when cranking can confuse the powertrain control module and set faulse codes, and or drivablty problems. I have seen alot of money spent on parts and labor just to find a bad battery in the end.
#3 |
I'd suggest stopping by one of the Auto Parts stores & have them do a FREE test on your battery, & charging system..
![]() .......Two Thousand and Eight, HHR Panel 2LT +......... |
#4 |
If the garage could not get a code, it could be their code reader wasn't able to communicate with the car's system - I had to get a new reader when I found my older one would not work with the HHR.
I'd suggest trying one of the auto parts chain stores to retry reading the codes - is it Autozone that does it free down your way? Sleeper probably knows. :) and they can probably test your battery at the same time.
#5 |
also found this - maybe related:
Subject: Intermittent Check Engine Light On, Engine Power Reduced Message Displayed in DIC, DTC P2135 Set (Inspect Engine Wiring Harness for Chafing and Recrimp ECM Terminals, if Necessary) Models: 2006-2009 Chevrolet HHR with 2.2L or 2.4L Engine (VINs B, D, P, V -- RPOs LE8, L61, LE5, LE9) -------------------------------------------------------------------------------- Condition Some customers may comment that the check engine light is on and an engine reduced power message is displayed in the DIC. A scan tool may reveal DTC P2135 set as current or in history. Cause This condition may be due to poor terminal crimps within the ECM connector, resulting in resistance at the affected circuits. Correction Perform the following as necessary. Inspect the engine wiring harness for potential shorts to ground in the following locations and repair and reposition the circuits/harness as necessary: • on the ECM/PCM case and/or on the edge of either ECM/PCM connector body • at the UBEC bracket • at the cylinder head plate (power steering pump blockout) • at the EVAP purge valve bracket • at the rear of the cylinder head/upper edge of transmission bell housing If after inspection of the engine wiring harness reveals no chafing in the areas identified above, follow SI procedures to recrimp the terminals listed below. These terminals are located in the ECM connectors. Use release tool J 38125-213 and J 38125-641 crimp tool (H jaw). Install each terminal back into the correct connector cavity and re-evaluate the concern. For additional information refer to the Engine Data Sensors -- APP and TAC schematics and the Engine Control Module Connector End Views. 2006 2.2L L61 Engine ECM Connector Function Pin Circuit No. C2 Throttle Position Sensor 1 Signal 58 485 C2 Throttle Position Sensor 2 Signal 36 486 C2 Low Reference 29 1704 C2 Low Reference 31 2752 C2 5 Volt Reference 24 2701 C2 5 Volt Reference 26 1688 Subject: Intermittent MIL/SES, DTC P2138 with Reduced Engine Power (Repair Instrument Panel (IP) to Body Harness Connector) Models: 2005-2008 GM Passenger Cars and Light Duty Trucks (Including Saturn) 2005-2008 HUMMER H2 2006-2008 HUMMER H3 2005-2008 Saab 9-7X -------------------------------------------------------------------------------- This Bulletin is being revised to add additional diagnostic service information. Please discard Corporate Bulletin Number 07-06-04-019 (Section 06 - Engine/Propulsion System) -------------------------------------------------------------------------------- Condition Some customers may comment on an intermittent MIL/SES light Illuminated with a message center or an indicator that displays Reduced Engine Power. DTC P2138 - Accelerator Pedal Position (APP) Sensor 1-2 Correlation may be set. The voltage difference between APP sensor 1 and APP sensor 2 exceeds a predetermined value for more than a brief period. Refer to DTC P2138 in SI for further diagnostics. Cause On some vehicles, the IP to body harness connector, which carries the APP signal to the ECM/PCM, is located in the left hand kick panel area or inside the IP. Water intrusion into these areas could cause an electrical short in the APP circuits setting a P2138 code. Correction Note: Make sure that no add-on/aftermarket equipment is electrically connected to the APP signals or to the other ECM/PCM five volt reference or return lines. These can generate false P2138 and/or other ETC System DTCs. If there are other engine DTCs besides P2138, such as MAP sensor faults (i.e. P0107, P0108), resolve these first before attempting to diagnose P2138 DTCs. Important: Refer to DTC P2138 in SI to confirm that the ETC pedal is operating correctly. Locate the IP to body harness connector, which may be located in and around the left hand kick panel area or inside the IP. Check to see if there is a water leak into the area and repair as necessary. Use a water hose to determine the source of a water leak and effectiveness of repair. Some examples of potential water leaks are: A-pillar seals, sunroof drain lines (if so equipped) and windshield/cowl sealing. Finally, repair or replace the IP to body harness connector, making sure no corrosion or debris is left on or between the terminals. in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
#6 |
Well, I went and got the battery tested today and they said it was still a "good battery." I went to a different garage and had them check for codes, and all they could find was a "Ignition Switch Circuit Fault" or something. He asked me if I had tried using any other keys lately and I said "no". He thought maybe my key was getting worn out and maybe I should try using my spare key instead. But of course, I doubt that any of this key business caused my Eng Pwr Reduced Light to come on. When I drove it today, it was back to normal. No Eng Pwr Reduced or Check Engine Light was on. At this point, it's running normal again, but I don't completely trust it. Is this a type of issue that will be recurring?? I'm not sure what to expect. I don't know if I should just leave it as it is now and hope it doesn't act up again, or if I should try and dig deeper to see if something is wrong. What do you think?
#7 |
Member #: 2294
Posts: 932 |
One possiblility that comes to mind: If you had to jumpstart it, the battery may have been drained at the time. If you have since charged it (or driven it enough), it is now properly charged and the problem is gone. The question remains why the battery died in the first place.
2008 Black HHR SS Auto, GMPP stage kit, Forge BPV 2007 Ford Freestyle Limited (Wife's) 2005 Kawasaki Z750 (The toy) 2006 HHR 2LT SOLD |
#8 |
I usually leave my GPS plugged in at night. I've done that for quite a while now. I haven't really had that much trouble overall with my battery. I don't know if that could have caused it maybe?? I wouldn't really consider a GPS to be the type of thing to drain your battery completely. It was so low I could even open the liftgate.
#9 |
GPS will drain your battery. Had it happen to me once on the wife's car (Lincoln MKZ). Drained it DEAD!
-Chris aka Gas Man "Why pay some one else to mess up your ride!" September 2010 Featured HHR **Thumbnails posted by me will always enlarge, just click em** |
#10 | |
GPS draws roughly 1/4amp, enough to drain a battery overnight.
From GPS Forums: Quote:
| Thread Tools | |
| Display Modes | |
