Old 01-19-2011, 03:47 AM   #1
geg
Member #: 20015
Images: 342
fuel gauge - died.
two days ago, fuel gauge started to go crazy. Arrow dropped to zero, then rises up. Today, fuel gauge died.
I called diagnostician, a question - diagnosis, if possible.
Diagnostician, said:
Problem widespread, in the fuel tank - float. This float is rigidly connected to the rheostat. In other words, the float scratching some PCB when moving up - down. Over time, wear an electronic board. Fuel gauge does not receive the signal and dies.
I need to buy this PCB or I do not know the name. I Ordered will be in the U.S. or Canada - in Russia it no.
Guys! Recommend seller. I want to pay through Paypal.
Thanks in advance.
enjoy every second
geg is offline   Reply With Quote
Old 01-19-2011, 04:13 AM   #2
Lucky
Lucky's Avatar
Member #: 5120
Images: 24
I would try ebay. sounds like you need a fuel sending unit. It may only come with the fuel pump not sure
Lucky is online now   Reply With Quote
Old 01-19-2011, 04:30 AM   #3
geg
Member #: 20015
Images: 342
I look at Ebay.
I'm afraid you're right. Big money - I'm not ready.
Perhaps there is a seller of Electrical components. You have the information?
enjoy every second
Old 01-19-2011, 10:13 AM   #4
PhoS
Member #: 3345
From what ive seen its GM part Number: 15293416
Cost is anywhere from $50-$75 USD
PhoS is offline   Reply With Quote
Old 01-19-2011, 05:12 PM   #5
Lucky
Lucky's Avatar
Member #: 5120
Images: 24
heres one on ebay it looks like you can get just the sending unit. 270692927247 also gm parts direct has them for 45.44
Old 01-19-2011, 07:33 PM   #6
Gas Man
Member #: 18523
Images: 27
Let us know if you have problems with shipping. I know I'll try to help if I can.
-Chris
aka Gas Man
"Why pay some one else to mess up your ride!"
September 2010 Featured HHR
**Thumbnails posted by me will always enlarge, just click em**
Gas Man is offline   Reply With Quote
Old 01-19-2011, 08:45 PM   #7
AJochum
Member #: 5461
This is probably not the answer, but have you tried using and additive in your gasoline? On many tanks the sending unit builds up a laquer like substance on the unit which keeps it from moving up and down. Just used in on my GMC Safari and it now works just fine. Many auto parts stores sell this in the US for about $7-10 a bottle.
AJochum is offline   Reply With Quote
Old 01-19-2011, 08:56 PM   #8
stephenm
Member #: 8043
Images: 9
I found a cross number of P/N 19168519 if that helps you
2008 IBM SS
AT, Roof, Side Airbags
LNF GM Performance Turbo Upgrade p/n 19212670
Join The HHR SS Facebook group
stephenm is offline   Reply With Quote
Old 01-19-2011, 09:00 PM   #9
IgottaWoody
Member #: 5336
Images: 20
before doing anything, check the connector on the tank first..you have alot of exposed area in the back and it would be easy for some trash to knock something loose......
"Creativity is Intelligence just having Fun"
IgottaWoody is offline   Reply With Quote
Old 01-20-2011, 11:09 AM   #10
geg
Member #: 20015
Images: 342
PhoS, stephenm and Lucky - thank you for help!
Gas Man - loyal friend. I will definitely take advantage of your offer. I'll do it as often as you can only stand me. Spare parts - my weak spot. Thank you very much.
AJochum - valuable information. If possible, detail. Title, etc. Thank you.
IgottaWoody - valuable advice. I have not thought of. You're experienced. Thank you.
Continuation of the story.
I do not know how to interpret it.
And so.
After my post (posted in the office) I started the engine. Turned on the error.
I tensed up.
I called the diagnosis and reported the incident. I asked - car computer responds to the level sensor malfunction? The answer - no! Come to the repair shop, will looking!
I'm hot!
Three hours ago I arrived at the repair shop. Trying to diagnose. Failure - engine control module is not available.
Question: a possible cause? Answer: The module was dead! if you're lucky - died only electric wire!
Fu**ing mom! from the calculation of future costs of brain swelled and boiled.
I say diagnostician: "Vova! Crashed into a flat cake, but find the cause and manner of cheap repair!" Vova sends me to the dick and tells me that such work requires money and time = 1 day + 3000 rubles. And all this - no earlier than the medium. And if the module is dead - even 1 month for delivery + 2000 rubles. The price of the module it is not known, but not less than 10,000 rubles.
We were busy for another 30 minutes. The result stunned. Vova unhooked wires and connectors are processed fluid WD-40 and compressed air. After this procedure, a module found! Diagnostic computer to communicate with the module and determine the error code! Error - Faulty Level sensor.
But that's not all. Level sensor is awake! As if nothing had happened!
Here are my thoughts:
Twice I was forced to buy gasoline at the gas station unknown. Maybe gasoline was diluted with water - do not be surprised, but in Russia it can do. Now the weather is very cold. Bitter cold - even gear oil freezes. I think the float was formed ice and blocked the sensor. Lock the sensor triggers an error module. And the contacts are acidified long ago - the snow and temperature changes.
I will monitor the situation until Wednesday. If I am wrong in my calculations, GasMan - I'll turn to you for help.
enjoy every second
