Go Back   Chevy HHR Network > General Discussion > Maintenance and Upkeep > Coolant drain/flush/refill
Old 02-02-2011, 09:01 AM   #1
RICK167448
Member #: 20801
Hi! I have a 2007 LS with a 2.2 liter engine. Can I drain, flush and refill the engine's cooling system or is this something that should be done by the chevy dealer?
RICK167448 is offline   Reply With Quote
Old 02-02-2011, 09:39 AM   #2
solman98
Member #: 1557
Images: 20
Planning on doing mine this spring so I'll be interested to see if there is anything unusual when doing the HHR.
But to answer your question, it's usually a easy job to do.
2006 1LT, 5-Speed, Born 12/9/2005, but hidden in the deep Florida swamps.
Found 9/30/2006
Black chrome lower billet, black chrome custom grill, K&N, LED tails, stock fogs on aftermarket wiring kit, 48" RECON "Big Rig" running board lights, 18" Cobalt Polished alloys, turbo tech sway bar. all exterior lights swapped to LED's, 35w 5K DDM HIDs. Upgraded to SS front rotors.
solman98 is offline   Reply With Quote
Old 02-02-2011, 11:18 AM   #3
Lucky
Lucky's Avatar
Member #: 5120
Images: 24
Well I have worked for 5 different dealers in the past. only one of them had a flushing machine. It seems that most places ( not all ) just drain the coolant and refill the system. this only works if your changing the coolant before it gets ugly. antifreeze don't go bad it's the rust inhibiters that fails over time then corrosion sets in. I like to to least flush the system with a garden hose with the hoses off.
Lucky is offline   Reply With Quote
Old 02-04-2011, 06:54 AM   #4
BlackScreaminMachine
Member #: 14347
GM cars does have issues with Dexcool. I just recently did my 2000 Buick Century and it was pretty nasty. What we did was just a drain, and fill (w/ distilled water) and in the spring I will run a cleaner through it.
Car had 75k and is 11 years old so I guess I cant complain but at least we discovered the waterpump was going so it all worked out.
As for the HHR- Open Pet **** on the radiator, release cap, let drain more or less completely, then fill with coolant and distilled water mix, start car and let it work itself back in. I AM NOT SURE if there are bleeder screws on the thermostat housing but if it does you will be bleeding it that way. My LS1 did not have them but my 2000 Buick with a 3.1L v6 does. Go Fig.
2002 Pontiac Trans Am Navy Blue Metallic 12.30's @113mph
2007 Chevrolet HHR LT 2.2L Majestic Amethyst Metallic
BlackScreaminMachine is offline   Reply With Quote
Old 02-04-2011, 11:06 PM   #5
sleeper
Member #: 2558
Images: 3
I did my S-10 every 5 yrs with Dex-Cool (as per schedule), & It always came out clean..
I guess it you go a lot longer, you get crud..
Old 02-05-2011, 11:51 AM   #6
Snoopy
Member #: 950
Sounds like your car DOESN'T have a problem with Dexcool. It has A PROBLEM with lack of reasonable maintenance. But you qualified your statement in your next paragraph explaining the lack thereof.
Also, the GM cars having trouble with Dexcool has been remedied for a number of years now. New formulation for Dexcool and "gasket" material.
As others have stated, I also have used nothing but Dexcool in my vehicles for the past 15-17 years (I was a consumer test vehicle for the product), and have experienced absolutely no problems.
But to answer the OP's question.......
You can perform this service with a moderate amount of automotive ability. A few specialty tools help, but not necessary. However, even though I can perform this service, I will probably have the dealer perform it. I like the idea of the power flush (probably the only item that I prefer power flushed).
DO NOT fool with Old Men---
They didn't get old by being,
STUPID
Snoopy is offline   Reply With Quote
Old 02-10-2011, 11:58 AM   #7
urbexHHR
Member #: 14016
Images: 325
Do you have to buy Dex-cool at the dealer? Any time I go to Meijer or places like that, I just see the yellow Prestone stuff? Do I want to put that in my HHR, or leave it with Dex-cool?
Old 02-10-2011, 12:15 PM   #8
solman98
Member #: 1557
Images: 20
Advance sells it, I'm sure AUto Zone does also. Mine will get this done this spring, along with new shock/struts and battery (still ticking, but I know it's life is about over, lol).
Found 9/30/2006
Old 02-10-2011, 03:02 PM   #9
urbexHHR
Member #: 14016
Images: 325
Just wondering though, is there anything wrong with the Prestone stuff? We had to drain some antifreeze from the Lumina, and we replaced what we took out with Prestone. I'm pretty sure that car came with Dex-Cool, but the stuff that was in it was green. (Well brown since we added stopleak a few years ago...)
Old 02-10-2011, 03:09 PM   #10
djr1973
Member #: 15073
Images: 23
I have boughten Dex-cool at wally world before. The stuff I got was made by Prestone and it was in a grey/silver jug.
djr1973 is offline   Reply With Quote
