Go Back   Chevy HHR Network > General Discussion > Problems/Service/Repairs > Squealing noise on 2006 HHR
Old 04-16-2011, 03:18 PM   #1
meeks22
Member #: 23605
Hello. My wife's HHR is making a squealing noise. It's a 2006 LT with 2.4L engine and has slightly over 82,000 miles. It appears when engine has warmed up and is not really greatly affected by revving engine but will change slightly with increased RPM's. The noise appears to be coming from passenger side of engine so I have replaced alternator and belt tensioner assembly. Does not matter if AC is on or not, so that ruled out compressor bearing. I am going crazy trying to fix momma's baby. Thank you in advance for any suggestions/cures!
meeks22 is offline   Reply With Quote
Old 04-16-2011, 03:33 PM   #2
meeks22
Member #: 23605
Additional information; car runs fine (except for the horrible noise).
Old 04-16-2011, 06:17 PM   #3
Laco
Member #: 14820
Hmmmm, water pump, maybe?????
Laco is offline   Reply With Quote
Old 04-16-2011, 07:55 PM   #4
meeks22
Member #: 23605
thanks for the reply. Is water pump on passenger's side? Is it high or low on the engine. I got a response from another area recommending that I run without belt to eliminate all accessories. Will do that tomorrow after church.
Old 04-16-2011, 08:50 PM   #5
Laco
Member #: 14820
meeks, another possibility might be the electric fan, since you don't hear it until the engine heats up, and RPM's don't seem to directly affect it.
Old 04-17-2011, 12:35 AM   #6
sleeper
Member #: 2558
Images: 3
When you turn on the A/C, the electric fan should start working. If that is any help..
Also the water pump is on pass side up near the top, it kinda mounts inward, as the enclosed timing Chain spins it..
Old 04-17-2011, 07:07 PM   #7
meeks22
Member #: 23605
Success! I am ashamed to tell you all that my problem stemmed from a bad belt. I can't believe that I didn't replace this first, but hindsight is 20-20. The fact that the noise was not affected by RPM's certainly confused me, but a lesson learned here. Thanks to all that chimed in!
Old 04-17-2011, 08:34 PM   #8
RBradley
Member #: 24712
Thanks for the update.
RBradley is offline   Reply With Quote
Old 04-18-2011, 11:18 AM   #9
Laco
Member #: 14820
Glad it turned out to be minor, and you were able to solve the problem.
Old 04-18-2011, 11:53 AM   #10
solman98
Member #: 1557
Images: 20
I was gonna ask how the belt looked.....
2006 1LT, 5-Speed, Born 12/9/2005, but hidden in the deep Florida swamps.
Found 9/30/2006
Black chrome lower billet, black chrome custom grill, K&N, LED tails, stock fogs on aftermarket wiring kit, 48" RECON "Big Rig" running board lights, 18" Cobalt Polished alloys, turbo tech sway bar. all exterior lights swapped to LED's, 35w 5K DDM HIDs. Upgraded to SS front rotors.
solman98 is offline   Reply With Quote
Tags
screeching noise, squealing noise, whining noise
