Go Back   Chevy HHR Network > General Discussion > Maintenance and Upkeep > Bleeding/flushing brake lines
Old 05-01-2011, 10:09 PM   #1
blacky
Member #: 11076
Planning to bleed brakes. Had Chevy mechanic warn me about using pressure bleeder, advised gravity bleeding. Any wisdom on this topic would be appreciated.
blacky is offline   Reply With Quote
Old 05-01-2011, 10:25 PM   #2
843de
Member #: 21740
Images: 80
If you have ABS on your HHR, don't even attempt it, you need to have a scan tool to operate the valves in the brake controller or you will never get it bled. Why do you feel the brakes need bled, are you having issues with the master cylinder, leaking brake lines, etc?
We won it, we won it, we won it!!! RDE 2/15/98
On being left in a parking lot for 500 million years: "The first ten million years were the worst. And the second ten million years, they were the worst too. The third ten million years I didn't enjoy at all. After that I went into sort of a decline"-Marvin the Paranoid Android
843de is offline   Reply With Quote
Old 05-02-2011, 03:37 AM   #3
1Panel2NV
Member #: 3572
Images: 34
Pressure or manual bleeding will work fine. The order is RR, LF, LR, RF.
The brakes should be bled every other year or more often if you're hard on them.
1Panel2NV is offline   Reply With Quote
Old 05-12-2011, 09:41 PM   #4
QuickRick
Member #: 9457
Images: 31
bleeding brakes
Yup,
Panel is right, bleeding that old, wet fluid is just as important as any other maintenance. I'm thinking that you save damage to all of those expensive braking parts for what....$6.00? Then there is the safety factor of having dry fluid that won't boil, it is win-win. You will need a quart of any good brand of DOT3/4 you decide to buy.
The only time that you can get in trouble is when you let air enter the system, do you homework, read up on the procedure, always keep the reservoir full and go for it. Besides, regularly doing this task keeps the bleeders excercised so that they don't seize up and break off.
QuickRick
2009 HHR 2LT/07 Z06/10 CTS Sportwagon
QuickRick is offline   Reply With Quote
Old 05-12-2011, 10:09 PM   #5
VinceP
Member #: 23591
I have an electric vaccuum pump that I use when doing a brake job. Never had a problem with bleeding ABS breaks. Like the others say, just keep an eye on the brake reservoir when doing this job.
VinceP is offline   Reply With Quote
Old 05-15-2011, 08:03 AM   #6
interrex
Member #: 36704
Images: 1
Piece of cake with the right tools.
first panel van 2007 in Indiana 5 speed LT
Grey leather Foose wheels now has a back seat..Who in their right mind would put the power window buttons on the floor? SHOULD BE A LAW THAT SAYS WHAT EVER SIDE OF THE ROAD YOU DRIVE ON, THE FRICKING GAS CAP SHOULD BE ON THAT SIDE TOO! SOMEONE NEEDS THEIR HEAD EXAMINED.
interrex is offline   Reply With Quote
Old 06-01-2011, 09:46 PM   #7
urbexHHR
Member #: 14016
Images: 325
I'm thinking I should look into bleeding my brakes and putting new fluid in now that I've hit the 5 year 50k mile mark...
