ABS Light - C0045 code
Old 05-22-2011, 07:55 PM
jbiesent's Avatar
Hi all,
I've been receiving the ABS and T/C light on my dash each time I start my HHR and it has been staying for the duration of the drive.
I've pulled off the code C0045 - Left Rear Wheel Speed Sensor Circuit Fail.
Is this due to a bad hub? Or is there a sensor that can be replaced, or is this a different issue altogether?
I've searched but all I could find was just the description of the code.
Any help would be appreciated, thanks!
jbiesent is offline
Old 05-22-2011, 08:08 PM
It sounds like the ABS sensor has failed, its part of the hub assembly so you'll need to change the hub out. You can check the connector going to the hub for corrosion and/or looseness but in the majority of cases its the sensor itself that has failed. Rear hubs for ABS equipped HHR's can be found for between $130-160 US, they'll be a bit higher in Canada I imagine.
ghostdragon
02-04-2015 03:36 PM
Hubbcapp
06-26-2014 02:17 PM
jdevries
06-21-2014 06:53 PM
laylowcustoms
05-15-2010 04:30 PM
goetylsd
05-11-2010 10:32 PM
Quick Reply: ABS Light - C0045 code
