Old 09-14-2011, 06:16 PM   #1
esmarkey
Member #: 8160
Images: 144
Rear hatch won't open
I did a search but didn't find anything on this.
The rear hatch in my 06 won't open! When you push the button on the rear beauty bar nothing.... no clicking no noise....nada, nothing.
I checked the fuse (#10 in engine compartment) and it is fine. That fuse is shared with the sunroof, which works fine.
Any ideas??
Is there anyway to open this from the inside? I am wondering how hard it is to get open from the inside as both the button and the solenoid look like they are accessed through removing the plastic cover on the inside, which I assume you have to open the hatch to remove?
Help!
Eric
2007 HHR 1LT (wifes) - Built 10/21/06 adopted 4/27/07
2007 HHR Fall Limited Edition - Adopted 5/21/07 Sold 1/31/08
2008 HHR SS (my new replacement ) - Built 1/11/08 adopted 1/31/08
esmarkey is offline   Reply With Quote
Old 09-14-2011, 06:19 PM   #2
donbrew
Member #: 13699
Images: 4
There's a TSB for it. Opening from the inside is covered in the manual. It is thru that oblong access cover (3"x1" apprx) and a screwdriver.
donbrew is offline   Reply With Quote
Old 09-14-2011, 06:24 PM   #3
Greybeard999
Member #: 19723
Images: 120
You will have to crawl through from the front, but if you look at the embossed ridges on the inside gate trim you will see one of them looks different...... It's a cover that can be removed.... there's a release inside that cover. (I think you need a screwdriver to get it though)
As far as the problem, check all the wires/connectors, if they are good I would say it's possibly the switch itself. You can test it with a meter, should just be a momentary contact switch......
____ ***** October 2010 featured HHR ***** ____
>> 2.4L, GMPP, Trifecta, Ground Force/Progress suspension <<
Greybeard999 is offline   Reply With Quote
Old 09-14-2011, 06:25 PM   #4
Snoopy
Member #: 950
Try this........
http://chevyhhr.net/forums/showthrea...ght=rear+hatch
DO NOT fool with Old Men---
They didn't get old by being,
STUPID
Snoopy is offline   Reply With Quote
Old 09-15-2011, 06:41 PM   #5
esmarkey
Member #: 8160
Images: 144
Originally Posted by Snoopy View Post
Thanks Snoopy!! That will help me get it open, then I need to find out how to get the entire panel off so I can check the switch...
donbrew, any more info on the TSB? Is that for getting it open, or the latch failure?
Eric
Old 09-16-2011, 12:04 AM   #6
Member #: 196
Images: 247
The TSB is for the touch pad actuator. Dory had the same issue back in 05.
Here's a link to the original thread on this issue. TSB on page 3..........
http://chevyhhr.net/forums/showthread.php?t=365
Dory born 7/18/05
>>>>>CLICK HERE TO BECOME A MEMBER!!<<<<<
If you spend a perfect afternoon in a perfectly useless manner, then your dog has taught you how to live
jx3 is offline   Reply With Quote
Old 09-16-2011, 12:32 PM   #7
Snoopy
Member #: 950
I'm only guessing at this, esmarkey, but I think your vehicle is out of warranty.....and the TSB is only an ADVISORY on HOW TO complete the repair. Doubt that your dealer will perform the repair without a charge.
So. if you are sure of which part is the failure, the repair can easily be done by you...without adding the cost of the dealer labor....or that may be your intent.
STUPID
Old 09-16-2011, 07:03 PM   #8
donbrew
Member #: 13699
Images: 4
Getting the panel off is an adventure. Get the top stop light cover off, then on the bottom edge of the door you will see 2 or 3 plastic plug things to remove, then pry and pull the rest of the thing off.
Old 09-19-2011, 01:19 PM   #9
esmarkey
Member #: 8160
Images: 144
Definately out of warranty, I'm gunna try to tackle this one myself.
Thanks for th ehelp!
Eric
Old 09-19-2011, 01:19 PM   #10
esmarkey
Member #: 8160
Images: 144
That's what I was looking for, Thanks.
Eric
