| Problems/Service/Repairs If you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post! |
#1 | ||
Member #: 54717
Posts: 11 |
#2 |
to the forum tgp1994! Here's a trick to try, lock the door with the key not the power lock button, then open the door with the key....the horn should stay blissfully quiet. If it doesn't work the first time, unlock all the doors, then lock each door manually and then lock the driver's door with the key. Then try unlocking the driver's door with the key, the horn should remain silent.
We won it, we won it, we won it!!! RDE 2/15/98 "My definition of an intellectual is someone who can listen to the William Tell Overture without thinking of the Lone Ranger." - Billy Connolly 4 HHR's(2011 "Boo Boo", 2007 "Paddington", 2007 "Bob 2", 2006 "Spousemobile") |
#3 |
Member #: 54373
Posts: 728 |
When I bought my HHR last month, the fob had the same battery connection issue and when I tried the key in the door my alarm went off as well. I even found a thread about this either on here or another forum, I don't rememeber which one. That just seems to be the design on these cars and unforetuneately you just have to live with it I think. I have a soldering gun so I just fixed my fob and all has been well since.
Like you found, I believe the people in that thread said locking it via the key in the drivers door was the only way to lock the car without arming/setting the alarm. Then when you use the key to unlock it the alarm is not active and will not sound off. |
#4 | ||
Member #: 54717
Posts: 11 |
Interesting idea about manually locking the doors. I think I'll give that a try. The issue I found with only locking the driver's side door with the key is that, it only locks the driver's side door :P Quote:
#5 |
Member #: 22523
Posts: 122 |
I already had to re-solder the battery connections in both of our fobs. It wasn't hard to do.
#6 |
Here's a link to a description of how to resolder the broken battery contacts - hope it helps: http://chevyhhr.net/forums/showthread.php?t=22641
#7 |
Member #: 54717
Posts: 11 |
Awesome guys, thank you :)
#8 |
Member #: 24127
Posts: 914 |
@tgp1994, how did things go with using the key to lock and unlock your doors on your HHR? Were you able to get your soldering job done for your fob?
Michelle, Chevrolet Customer Service |
#9 | |
Member #: 54717
Posts: 11 |
Thanks for checking in! |
#10 |
Member #: 24127
Posts: 914 |
@tgp1994, I apologize that the suggestion that you tried didn't work. I am glad that friend can solder this for you.
Don't hesitate to get a hold of me in the future. Michelle, Chevrolet Customer Service |
| Tags |
| hhr2006 alarm |
| Thread Tools | |
| Display Modes | |
