Sponsored by Ultrarev
Click Here
Old 12-28-2011, 11:58 AM   #1
fastsuv
Member #: 421
Wheel Bearing failure?
I have a noise coming from the front end that is a "buzzing" noise that varies exactly with vehicle speed. It sounds like the tire is rubbing on the fender liner (which it is not). The noise is loudest at 40mph and faster. If I swerve right at 40mph, the noise briefly stops. if I swerve left, it briefly gets louder. This all points to a bad driver-side wheel bearing.
However, I jacked up both front wheels (one at a time) and checked the bearings. There appears to be no play in the bearing in any direction. Also, I put the transmission in neutral and spun the wheel by hand and there was no obvious abnormal noise.
I have replaced wheel hubs on other cars before, and by the time the noise was this loud, there was a lot of play in the bearing. This time I don't see that. Could the bearing be noisy without being loose? Also, could the noise only occur under load (the weight of the car on the bearing), which would explain no noise when I spun the hanging wheel by hand?
I don't mind replacing a bad hub, but if it's something else I don't want to spend $120 unnecessarily.
Thanks
Steve
fastsuv is offline   Reply With Quote
Old 12-28-2011, 02:02 PM   #2
SmootHHR
Member #: 18842
Images: 128
Sounds like you have it right by suspecting the wheel bearing. When mine was bad, I thought it sounded like a knobby mud tires on a lifted truck. I had the same symptoms with the speed...above 35mph it got significantly louder. The bearings inside the assembly can be bad with no excess play in the wheel, from what I've seen (on my own hhr). For what it's worth, I had good luck with the hub assembly I bought on eBay for $75 shipped. I put the link in a different post, but I think it was from Timken. Shipped quick and very easy install. Good luck!
2006 1LT, Daytona Blue, 5spd
Built 8/4/2005
SmootHHR is offline   Reply With Quote
Old 12-28-2011, 08:51 PM   #3
ebritt
Member #: 10490
Thanks
Steve
i got the same thing, But it is not the bearings. Have your tires checked for "cupping" first. It can be very loud. Usually its an alignment problem, very common and can sound just like a bearing. Wont hurt to check.
If it does turn out to be bearings, I was surprised at how easy changing a bearing is on these cars. Firs time I did the thing practically changed itself, popped right out pretty as you please.
ebritt is offline   Reply With Quote
Old 12-29-2011, 07:24 AM   #4
hhrfreek
Member #: 19695
Images: 70
A few years ago I had a Cavalier and replaced both wheel bearings. Mine had play in them though so I did both and my car exhibited the same hum you described. Cured the issue needless to say, but it was obvious to me since I had play in the hub.
Get the tires/alignment checked for sure though. They can emit some weird noises sometimes.
Solstice GXP
hhrfreek is offline   Reply With Quote
Old 12-29-2011, 07:37 AM   #5
db/sb
db/sb's Avatar
Member #: 1280
Images: 8
If your vehicle's alignment is off enough to 'cup' the tires and make them 'hum' maybe you've waited a bit too long to have to have it checked.......
2005 Pontiac GTO M6 (My car)
1983 Chevrolet El Camino Conquista (Daily driver)
2010 Mercedes Benz C300 Sport w/AMG Sportline Pkg.(Wife's car)
2014 Kia Rio LX (Wife's daily driver)
2006 Chevrolet HHR LT (Sold 3/2/2013)
2008 HHR LS (Niece's-Sold 9/20/2013)
Family mechanic for nephew's 2010 HHR LT
Certified HVAC/MVAC tech
db/sb is offline   Reply With Quote
Old 12-29-2011, 07:45 AM   #6
AJochum
Member #: 5461
Thanks
Steve
Suspect you have a 2006 and it might just be out of warranty, but remember it has a 5/100,000 mile warranty on powertrain.
AJochum is offline   Reply With Quote
Old 12-29-2011, 11:17 AM   #7
fastsuv
Member #: 421
An update:
I tried a different set of tires/wheels on the front and the noise didn't change at all.
I'm going to spring for the new hub from Rock Auto and replace it as it seems fairly easy to do.
While I was checking the suspension, I noticed that the rear bushing on the driver side control arm was worn pretty badly. I noticed this when I was tightening the wheel lug nuts with a breaker bar and the wheel rolled back almost an inch in the wheel well before the car started to roll!
So I'll be ordering a control arm bushing also.
Thanks for the replies.
Steve
Old 12-29-2011, 01:21 PM   #8
ChevyMgr
Super Moderator
Member #: 4865
Images: 707
2006 models don't have power train warranty.
Old 12-29-2011, 02:34 PM   #9
AJochum
Member #: 5461
Me too! :)
Old 12-29-2011, 09:49 PM   #10
ebritt
Member #: 10490
This is true.
