Old 07-17-2012, 10:27 PM   #1
Lee3333
Lee3333's Avatar
Member #: 324
Images: 245
Alternator problems?
While waiting for my wife, I had the engine running with the a/c and radio on. When she got in the car, the radio started flashing off and on. After trying to adjust it, I decided to shut off the engine then restart it. The battery was dead. The voltmeter I installed showed only 10 volts. I boosted the car and took the battery out and put it on a tester at Pep Boys. They fully charged the battery and it tested to be fine. Now I see that the voltmeter is only showing 12 volts when I am driving. I know it should be over 13, but it is a cheap gauge and I have no engine codes showing. Think the alternator could be on it's way out? Tomorrow I want to bring it to my friends shop, have the codes read, and put a good voltmeter across the battery.
Lee3333 is offline   Reply With Quote
Old 07-18-2012, 06:48 AM   #2
solman98
Member #: 1557
Images: 20
You should be running 14-14.5 volts.
2006 1LT, 5-Speed, Born 12/9/2005, but hidden in the deep Florida swamps.
Found 9/30/2006
Black chrome lower billet, black chrome custom grill, K&N, LED tails, stock fogs on aftermarket wiring kit, 48" RECON "Big Rig" running board lights, 18" Cobalt Polished alloys, turbo tech sway bar. all exterior lights swapped to LED's, 35w 5K DDM HIDs. Upgraded to SS front rotors.
solman98 is offline   Reply With Quote
Old 07-18-2012, 08:11 AM   #3
Lee3333
Lee3333's Avatar
Member #: 324
Images: 245
I know, but the gauge is a cheapo and I don't recall it reading much higher than 12. But wouldn't I have gotten some warning light if the alternator was not working right?
Old 07-18-2012, 10:02 AM   #4
Snoopy
Member #: 950
I don't think you had a alternator problem. You just drained the battery by sitting and using the radio and a/c, probably on a higher blower setting.....and remember there are other electronic/electrical powered functions in the "invisible" background.........for engine operation, dash gages, etc.
My daughter did this every summer waiting for kids at school, swim club, track team, etc.
I'm told, by a GM engineer, that occasional idling is acceptable with SOME power accessories running. But an owner should run the car at higher RP M's if sitting more than a couple of minutes......conversely, a run on an Interstate is the best resolutions.
So, I suggest taking a long run on the Interstate to see a friend (remember to turn the engine off while talking with him/her.
Oh, and if I remember correctly....when you drained the battery that low, it may not return to full and reliable charge.
DO NOT fool with Old Men---
They didn't get old by being,
STUPID
Snoopy is offline   Reply With Quote
Old 07-18-2012, 10:04 AM   #5
firemangeorge
Member #: 18078
Images: 54
Warning lights or CEL's are not always accurate. Do not depend on them to be your only diagnosis.
They're nice when they give you a warning but don't blame the car if something breaks and you don't get a "light".
Sounds like you have a bad alternator OR a bad wire/power connection to the charging system.
2010 HHR SS, 5spd, LSD, Brembos
TTR rear sway bar
TTR front mount
GM Turbo Upgrade
Forge Motorsports BPV
Pedders Sportsryder springs
Flowmaster HP2 Shorty
firemangeorge is offline   Reply With Quote
Old 07-18-2012, 10:04 AM   #6
solman98
Member #: 1557
Images: 20
Have it tested. Most, if not all, auto parts stores will test it for free. Then you will know.
Found 9/30/2006
Old 07-18-2012, 10:30 AM   #7
Lee3333
Lee3333's Avatar
Member #: 324
Images: 245
This morning when I started the car to drive my daughter to camp, the voltmeter read 14 volts for a few seconds then dropped to 12. Stayed that way as I drove, dropping to about 11 when stopped at a light and engine RPM low. I went by my friends shop and told them I was going to bring the car in to test/change the alternator (and belt while at it). I went home to get my other car keys and tell my wife to follow me there, then drove back to the shop. Now the voltmeter was reading 10 at idle. Once I got to the shop, I tried to restart the car and the battery was dead. Feel pretty sure it is the alternator.
Old 07-19-2012, 11:47 AM   #8
Lee3333
Lee3333's Avatar
Member #: 324
Images: 245
Just got my car back and it turned out to be very lucky for me. The alternator was bad, but so was the serpentine belt. It had cracks and was ready to break.
And now my voltmeter is back at 14!
