How do you remove Vent Visors???
Old 06-05-2007, 07:11 PM
FXM
FXM's Avatar
I just attached my four vent visors on the "Chiller". They are the ones that are attached with 3M tape, Well, after they are installed, I noticed that the drivers side (back window) vent visor is cracked. How do I remove the broken visor so I can replace it?
Thanks
Doog Si Efil
F.X.
FXM is offline
Old 06-05-2007, 07:17 PM
courthousedeb's Avatar
Easiest way I can think of would be to let it sit out in the sun and let the car get nice and warm. Then, use dental floss or something similar and slide it under one of the ends and slowly move it from one end to the other until it comes off. You could also use a hair dryer to warm it up as well...just don't hold it in one place too long.
courthousedeb is offline
Old 06-05-2007, 07:23 PM
Black Beauty's Avatar
Are they in-channel or stick-on?
Both use 3M.
The in-channel will be more challenging, but hold off. I had a broken one, the vendor sent me an entire new set (free). I didn`t have to send them the broken one either.
I haven`t attempted to remove the cracked one yet, not toooo bad, just a worry.
Black Beauty is offline
Old 06-05-2007, 07:28 PM
JimZ_HHR's Avatar
To loosen up the glue, get Goo Gone from any auto parts store.
JimZ_HHR is offline
Old 06-07-2007, 02:49 PM
tcstoy's Avatar
Angry
The in channel ones come off easier than the stick outside ones. Removed some from in channel on my sons Ranger. Pulled out without too much effort. Removed some stick to the outside ones from my wifes 05 Sorento..............major pain. The tape stuck in places and had to rub off very slowly.
tcstoy is offline
Old 06-07-2007, 03:47 PM
scaleguy's Avatar
A blow dryer will al so help loosen the adhesive tape.
scaleguy is offline
Old 06-07-2007, 06:17 PM
Just noticed
Thanks
Doog Si Efil
F.X.
I just reread this and low and behold, that`s the same vent that cracked on me.
The rear drivers side, back where the rubber strip seperates the two windows?
From the outside it`s hardly noticable.
Old 06-07-2007, 06:24 PM
Alzonie's Avatar
That's the In-Channel Visor though isn't it? Not the stick on.
Alzonie is offline
Old 06-07-2007, 06:31 PM
Yeah, in-channel. I think the load on the end helped crack it.
Maybe the stick-on type will fair better, just showing the area for reference.
VersysRider
Mods - Exterior
10
02-26-2011 04:04 PM
Ponyman1
01-12-2010 12:36 PM
johnbegone
02-13-2008 05:04 PM
HipHotRod
South Pacific
10
01-29-2008 06:54 AM
jb291
03-26-2007 12:35 PM
Quick Reply: How do you remove Vent Visors???
