View Full Version : Audio and Video
Pages :
1]
- Turning off Alarm
- Looking for a specific feature
- Radio stops working after some time.
- 06 HHR head unit install w/ scosche kit
- Installing a new stereo
- Cheap android auto dongle
- 2009-2011 radio into a 2007
- Panel audio idea.
- aftermarket stereo no sound and car wont crank
- The VF display on radio unreadable
- Radio Replacement - pinout diagram confusing...
- Bluetooth streaming audio from stock stereo?
- Taking suggestions for replacement Stereo (Media Unit)
- Tapping sub wires for line output converter?
- 2009 hhr radio for garage
- SWC aftermarket stereo
- 2009 Chevrolet HHR 2.2L Radio Non Pioneer
- Sup ppl, got a question.
- 2008 Chevy HHR Radio Wiring Diagram Help
- About using RCA amp inputs
- Radio Turns Itself On
- Stereo upgrade for aftermarket amp and subs help
- tweeter replacement
- XM Radio Capabillty
- Where is the 12v battery wire
- 6.5" in rear window
- Rear speakers not working
- Is it the antenna that sucks?
- Modifying OEM Speaker Bracket
- CD/DVD Player
- Power Acoustik head unit in my panel
- PRV 6mr500 v3's on 200w rms (vid)
- Upgraded factory ground location?
- Big 3/4 worth it?
- Passing new wires through door grommet?
- Custom a pillars...cant find thread...here is the pic tho
- 8" mid mounted outside of door panel?
- Will any other GM radios work in the HHR?
- Where to mount second 6.5" on the door?
- Unlock my radio cost my 1st born......
- Sending component speakers back, going for coax in the front`
- Pioneer system speaker question
- Added Powered Subwoofer
- Tweeters sound way better up here
- What is wattage output on 2010 SS stock amp?
- Coaxial instead of Component
- 2011 HHR LT 2.4 - Factory Audio Wiring colors & diagrams
- 2008 HHR SS Radio jumps to auxiliary input
- HHR Tweeters work intermittent doors
- Left rear speaker fix
- DVD Audio weak
- Car stereo installation issue
- 3 Speakers not working
- Rear view mirror upgrade
- Advice on updating audio
- Looking at changing the head unit
- fixed the speakers
- New owner with audio questions
- Planning a HU upgrade and sub/amp install.
- Radio Troubles
- voltage question
- Mounting a cb radio
- Hopefully something easy???
- Whats the Difference in these 2 radios? (UUI)
- Aloha 08 Radio troubleshooting
- New CD player questions,,,,,
- radio antenna coax
- Looking for various specs
- Radio install
- Typical sound issues
- No FM
- Looking to upgrade speakers in 2006 LT!
- Rear door speakers inop
- missing speakers?
- New subwoofer enclosure
- 2006 HHR no power to radio
- SiriusXM radio while keeping stock look
- aftermarket radio
- Wiring for Pioneer radio into 09 HHR
- Aftermarket double DIN Pioneer stereo install. PLEASE HELP!!!!
- Taking premium system from a 2009 and putting it in my 2006 Lt
- HHR racing fox body Mustang.
- am/fm problems
- Installing Aftermarket HU without GMOS-LAN-04 & retain factory amp / sub
- Headrest speakers
- Head Unit upgrade
- 07 LT, New HU install....
- Lost bass and mid-range on stereo
- turn chimes off
- Blank radio display
- Chime module.
- ??interface?? Gm3000
- 2011 HHR Sirius intergration antenna issues
- Rear quarter panel window hollow
- Installed new stereo without factory harness. Only front left speaker works
- Bluetooth Problem
- 2011 HHR aftermarket headunit wiring interface
- Intermittent Poor Behavior for Steering Wheel Volume Controls
- GM p/n 821607108 Subwoofer assy
- Aftermarket Stereo Install ...oh good grief
- No FM reception, minimal AM reception now
- JL Audio 13w7 spare tire area subwoofer box
- unique keyfob question
- To mod or not to mod
- ATOTO android radio installation question
- Dual 6.5" front doors?
- Stereo/Speaker Issues
- Xm radio
- Sound issues. Please help
- What would you do about this stereo
- On star mirror
- Bluetooth
- Just started losing sound this morning.
- Need help please i just replace the factory radio for a boss bvcp9675a
- Intermittent issues
- Radio upgrade - Antenna, GPS, OnStar, Chimes, etc
- Intermittent Connection to Back of Radio
- "New" 2011 LT OnStar Question
- BAFX ODB 2 question
- fuse #24
- USB Connection Question
- Rearview Camera Wiring
- Will other stock radios work on HHR?
- Replacing the radio antenna
- Bad fade and balance
- Stereo Tweeters only working audio
- Stereo speakers
- New Aftermarket Radio Install...
- ohms rating on speakers
- No sound
- Newbie question...2006 LT wiring harness???
- 11 bit interface
- Factory Pioneer amp
- aftermarket radio installation
- High pitch whine.
- Right Tweeter Problem
- sub woofer
- Another speaker issue
- Speaker problems
- Install question
- 08 SS PreSet Jumping Around
- Speaker help, Left rear hardly working
- Wet Speakers
- OnStar/SiriusXM Antenna Rubber Mast Removal
- Figuring out the stereo in a 2008 LT
- car audio problems 2010 HHR
- Installing Amp/Sub and door speakers
- Need help from an audiophile
- Factory amp tap
- Helpful list for pairing phone to car
- Bluetooth conection problem
- Steering Wheel Audio Controls Won't Work
- Steering wheel with audio control
- On Star and XM disconnect
- Which wiring harness?
- Another factory radio question
- Factory Bluetooth unit in 2008
- Replacing The OEM radio with an aftermarket Navi! please somebody HEEELP! :(
- Radio antenna ground question
- Which is power antenna lead?
- Double din aftermarket stereo help.
- Front doors speaker replacement question
- Stereo Installation
- Instructions To Swap US8 For US9?
- 2 antennas.
- Radio Bass & Treble Resets Itself
- anntena radio original
- Aftermarket amp wiring under hood
- USB / Aux extender into top cubby
- The HHR shirt dance
- Where to put headunit wires without cutting?
- 95-3302S Dash Kit
- XM Help
- Pioneer head unit change question.
- Orig Radio: signal drop
- Bluetooth For Playing Music from iPhone
- Pioneer 6CD CHANGER MODEL 15832814 FOR 2007 HHR LT
- A good place to put an amplifier
- 2007 panel rear door speakers?
- Amp adjustments
- Back up camera goes black
- Rear (XM/OnStar) antenna question
- New Radio, backup camera, sub/amp, and more! (Pictures inside)
- New headunit, sound sucks now
- Xm radio tuner
- Electrical anomally
- Door speaker help
- Smudges on Radio Display
- Head unit replacement
- BCM #6 "Amp" fuse?
- Power Source for Underseat Powered Sub?
- REQUEST - Bluetooth add-on How-To section
- Warning Chimes Not Working
- USB intermittent, multiple flashdrives
- Rear speakers
- need advice on installing tv in back
- New head unit with nav. Installed
- No phone calls on Bluetooth
- Premium 09 SS Head Unit Question
- Adding 2nd AUX input port
- CD player not working
- No power to the radio fuse location
- Faulty radio antenna amp?
- Amp repair
- Speakers
- Hiding speaker wires for doors
- Factory Speaker Adapters?
- Help with XM Radio
- 2010 chevy hhr stereo wiring diagram
- bigger wire to front doors
- I want to add steering wheel controls
- Radar Detector Hardwire Help?
- Speakers Not Working in the Morning
- Installing amps questions
- Changing out factory stereo and all four speakers
- I want to install a new HU/Radio in my HHR
- change dome light
- Kick panels for 6.5" or door pods for 2 6.5"?
- Stereo system upgrade
- 2007 hhr radio dial won't illuminate
- Cheap H.O. Alternator?
- Stock radio issue
- Bluetooth Mirror
- weather impacting my speakers?
- locked radio ? need codes or help
- Go back to the original stereo in 2008 HHR SS
- Free upgrade love Sound Stream !
- Speaker Sizes?
- Audio help needed!!
- New cd player install
- Radio does not work
- Starting my stereo upgrade.
- Pioneer Stereo Headunit Replacement
- Powered Sub install
- Head Unit and/or Speaker replacement
- Crackling noise
- Radio seems inop after dead battery
- USB drive not being read
- Got Hollered At Yesterday by some Teens!
- Rear speaker cutting in and out
- How to sort music on a USB drive for the factory stereo system
- 2011 HHR stereo question
- Installing a Pioneer GPS Receiver, what to expect?
- Speakers randomly go in and out, in groups
- How to sort your music on a USB drive for a GM factory radio
- ID3 data not showing up correctly
- USB drive
- OEM subwoofer
- 2011 HHR 1LT(we think) XM options
- Amp install now buzzing ???
