- Side mirror plastic hot glue fix first attempt
- SS - How to replace braided line from valve cover to air inlet hose
- Lower Control Arm Cage Nut Replacement
- p0332 Knock Sensor #2 Replacement *Easy Fix
- How to change or edit signatures?
- Front hub replacement
- How to fix a window issue (09-11 and SS)
- replace timing chain gasket
- HHR Fuel Door removal
- Clutch Hydraulics
- code P0340 fixed
- Caution about using water pump sprocket tool
- Installing ZZP o2 bung extender
- For the novice
- Front inner fender fasteners
- How to replace the intercooler ZZP - SS
- online shop manuals
- Air Conditioning chart
- replace dash Vent Louver
- Rust on the wheels – removal
- Tips for struts and shocks installation
- Engine rebuild guide
- Fuse box information
- How-to install 3 bar TMAP sensors - SS - alternative way
- How-to install upgraded timing chain guide bolt
- Thinking about rear disc brakes on your LS/LT ?
- How to change the Ambient light sensor
- After market armrest
- Engine assembly video
- Upper dash pad removal
- Fuel line follies!
- Grab handle
- HHR Remote fix
- Cleaning window switch contacts
- Rust on the door – removal
- 2007 front wheel cover reattach
- Panel Mechanical Door Popper - Door Side
- Seat swap to Leather wirh Elec Seats - Questions Air Bag sensor
- Replacing the TPMS sensor battery
- HHR wiper linkage
- How to burp Cooling system.
- Timing chain kits
- HHR Overheat Timing Balance Shaft Nightmare
- Spammers and how to deal with them
- Fuse Box Follies (underhood fuse box information)
- Manual transmission replacement - 2008 2.2 LT1
- Heated side mirrors conversion with pics
- NEW Gallery
- Rear Wiper Mod
- How to fix sunroof deflector for 4 dollars
- Sway bar bushings?
- Remove and replace steering rack
- Install 1999 Chevy Blazer OverHead Console
- Teardown of the 4T40-E and 4T45-E Automatic Transmissions
- How to Upload and Add Pictures to your Post
- ATF and filter change
- J. Hunto's Garage - HHR Maintenance Videos
- Replacing the Oil Pressure Sending Unit
- Dropping Engine Cradle without a Lift
- How to replace engine air cleaner/filter
- Alternator replacement 25 minutes
- Removal of Rear axle bushings
- How to Drain(and Flush) Coolant - SS
- Simple GPS mount
- Use Factory Speaker Frame to Mount Aftermarket Speakers
- Dignosing the CAN bus
- How to fix your "wooly worm" (fresh air intake hose) for good
- ground locations
- Water pump replacement
- Easy duel horns
- How to reply to a thread (desktop site)
- How to start a new thread
- Water Diverter Fix
- How to Shell Blast Intake Valves - SS
- How to Remove Intake Manifold -SS
- How to Remove Stock Airbox - SS
- Generic "How-to Videos"
- FOUND: Rearview mirrors, don't put up with the dim yellow LED maplights!
- How to perform a leak down test (engine)
- HHR clutch replacement how to
- How to: Check a wheel hub bearing assembly
- How to repair worn clutch pedal arm
- 2006 HHR Shifter Photos
- HomeLink Install
- Replace Antenna Base
- Tightening Torque Values for Common Maintenance Items
- Replacing Vacuum Pump on SS
- Building an oil catch can for the SS
- Replacing a Direct Injection(DI) Fuel Pump
- 2010 HHR SS Adding turbo gauge to A pillar
- How to program your key fob using a Tech II
- How-To edit your signature
- The Tool I Use......
- Shifter stuck in Park fix
- Key stuck fix
- video-sway bar bushing replacement
- Fix storage bin latch
- What do I do now, I have a Check Engine Light
- oil pressure sender installation.
- Need third brake light access?-"How To" video here...
- 2008 HHR Donnley rear view mirror 7-pin wiring diagram
- Cabin Air Filter Change
- How To Remove Bumper Cover and Bumper Bar
- HHR Rear Dome Light will not Work
- Temporary Solution for non-working key fobs
- Cabin Air Filter? Well...duh!
- Good sound cheap.
- throttle body
- HHR clunk fix
- MAP sensor replacement
- How to convert to a LED 3rd brake light.
- Decisions I Use in Modifying and Tips on How to Do a Mod
- Not Baby Moons but small center incerts
- Homelink add on
- Some pics of fan replacement
- making your HHR recognize new radio
- SEARCH TOOL - at the top of each page - give it a try
- Tinting Headlights video - SS HHR used in video
- add LED courtesy lighting
- Mirror Switch Fix
- HOW TO: Rear Disc Brakes
- Install a hitch and transmission cooler
- YouTube Videos for various repairs
- How to take amazing pictures of your car(s)
- Building some projectors out of some Depo'd
- Parts Illustrations
- Timing chain tensioner replacement - fix engine rattle
- Door Lock Assembly Fix: Lots of Pics
- Removing & Re-Installing Exterior Door Handles
- EVAP Canister Vent Solenoid Valve Replacement
- Rocker Panel removal
- Replacing Lower Control Arms
- Make your own grill
- 3 hour Rusty door fix
- HOW TO: bypass valve spring replacement
- Steering Wheel Dissection - 2011 HHR
- Late night fix for an air cleaner housing bracket
- Air Lift (Drag Bags) HOW TO:
- How to fix broken interior door handle for less than $10
- How To: General Exterior Bulb Replacement
- Smoke out tail lights(how to)
- Inside door handle replace
- Led License Plate bulb install
- shift inter-lock repair/delete
- How To: Front hub replacement
- How To- Engine Basics
- HID INSTALL-Easy How To
- Running wires into doors
- Turn Signal Canceling Failure Fix: Lots of Pics
- How To Fix a Cracked Front Bumper
- Fuel Pump Replacement
- Tail light mod
- LED Headlight How To
- Fuel Line w/dampener replacement...no more gas leak...
- '09 FACTORY FOG LIGHTS with Custom Install
- How To Change 2008 2.2L Knock Sensor
- fog light install
- How to: SS Grille on LT - Cut to fit -Two methods
- Casual HHR dress code. "Removed Bowtie"
- How to fix wiper transmission
- Install Trailer Hitch- Part 2
- Install Trailer Hitch- Part 1
- Install Trailer Hitch- Wiring
- $2.44 Stubby How-To
- How To: Replace your dash gauges w/ Black Cat Custom
- Remove Front Bumper and Swap Headlights
- How to repair flex pipe
- Power Steering Motor Replacement w/Pics
- Wolo Bad Boy Air Horn Install (dial up hating)
- Repair Key Fob Remote's worn out contacts
- How To: Remove your rear SS bumper & bumper reflectors
- Good Instructions with pics..Short Throw Shifter
- How to replace stock horn with 12V dual note horns
- Wanna Cover that Hole in Your Rear? Hitch Hole that is!
- Rear Shock How-to
- How To: Reset the Security System/Relearn a Key
- Camshaft Position Actuator Solenoid Valve Replacement (w. pics) - P0010/11 P0013/14
- For those of us that still smoke-Installation of a usable ashtray today
- How to: Adding After Market Rear Seat Belts to a Panel
- How to add GM Remote Start without option AP3
- Front sway bar swap
- Console Creaking/Noise fix
- General brand snaps for cargo shelf
- removing automatic gear shifter
- Change the language on your gauges
- Rear Bumper LED mod - long post
- Install Rear Seat in Panel
- Installing Interior Dome/Mirror Light Switch
- Chrome Console Shifter Ring - Lifting Fix
- Plastic Collar Quick Connect Fitting Service
- Automatic ESC off circuit
- GMPP Intake Modification for reliability
- How to: convert your LS or 1LT to a 2LT
- How to install an HHR spoiler
- New 'HHR specific' splash guards installed:
- Rear Turn Signal Mod using Front Wires
- Convert 3rd Brake Light Turn Signal/Stop Light
- Rear sidermarkers as turn signals...
- rear view mirror upgrade (Magna Donnelly)
- Convert front side marker to work as a turn signal and marker lamp
- How to save $350.00 + (Thermostat Replacement 2.4L - P0128)
- Hood Insulation Logo
- Discontinuing the XM Radio “Band” on the radio!
- DIY "1/2" Panel
- How to remove tree sap
- Angel Eyes DIY
- Removing the rear bumper cover/fascia
- Fixing broken door handles on HHR
- How to remove the "Headliner"
- I added front interior DOME LIGHT.
- Keyfob cold solder repair
- How To:Change Rear Wiper
- How to install HID Bi-Xenon Lights
- How To Carpet In The Back
- How to: Liftgate Emergency Switch
- LED MOD - Radio, HVAC, I/P - Step-By-Step Tutorial 2006-2008
- Cargo Mat & net
- Adding a 2nd Aux Hook-up to 07 HHR
- Changing LED's in Radio, Heater Controls, & Instrument Panel
- How do you replace the rear window wiper blade?
- DIY Roof Rack Install
- sunroof/headliner rattle easy fix
- Installed new Maplight
- How to Replace HVAC Blower fan/motor
- Quieting that trailer hitch
- 08 shifter change to 09
- License Plate Lights Replacement Help
- How to Paint Your Headlights
- Dome light turn around...
- How to Modify Ebay Fog Lights
- Fog light switch mod how-to.
- How to new Shift boot and short shifter.
- Rear wiper removal mod??
- How to Remove the Roof Rails
- 3 Bar Chrome Mod Advice
- How to remove shifter handle automatic.
- How to replace rotors and pads on 06 HHR
- Studs & Brake Rotor Change - Solstice Wheels
- SS Intercooler Grille Removal?
- How to fix the armrest
- Fixed my water leak, last night!!
- How To Install A New Horn
- Door Panel Removal
- Relocating Front License Plate
- How To Install Scripts
- Seat removal and carpet install
- headliner rattle repair-sunroof models
- How to Install an Aa Oo Gah Horn
- How to clean and wax stock wheels
- Sunroof quick fix (for those without warranty coverage)
