View Full Version : General HHR
- Does my exhaust look bad?
- Tow Hitch Installation
- New To Me 2008 HHR SS
- Advice on selling
- Won't start
- 06 2.2 exhaust manifold question
- Thoughts on used HHRs
- HHR 4x4 Build
- Fuel Guage Follies
- Consensus regarding front rotor warping?
- New here! Q: Simplest options to put an mp3 sd/gps touch screen in an 06?
- Just another stubborn P0172 code
- Drivers side headlight turns off. Passengers side stays on
- Where’s the air
- still issues with the first gear after shifter cable replaced
- Code P0171
- Turn signals won't cancel
- Need Hope to figure out what kind of harness I need
- Think we got bamboozled.
- Replacing oil pressure switch but concerned about starter...
- Transmission acting funny .
- Tire pressure sensors and key fobs not working.
- this shht happens too
- Back to HHR SS!
- Something scraping underneath
- Looking to buy an hhr panel WITH NO REAR WINDOW
- Headlight compatability
- Tie rods replacement
- new shifter cable need HHR 2006 manual
- Rear windshield wiper
- Alarm system.. sort of...
- Fog light switch
- Advice on purchase.
- 2009 HHR needs cylinder head replacement
- Possible self-alignment?
- Sun visor clips
- Had the rear shocks changed about 5 months ago.
- Don't leave a dexcool container in your car if its cold :(
- Whats the deal with Traction and Power ?
- Buying another HHR?
- 1158125
- Question regarding traction on snow
- Piston ring replacement
- Dealing with condensation / moisture inside the car
- The Minister of Sinister is coming back !!!
- HHR 'Panel' Emblem
- risk of buying a 2008 SS due to porous block?
- Fuel line insulation question
- Cooling issues
- Surprise, Surprise!
- Remove wiper arms, 08
- Hhr power window problem
- 2007 HHR 2.4L died
- Drivers side mirror
- Front end questions
- New member with a/c problems 2009 2.4L
- Brake line question...
- New struts and rear shocks?
- Done did it again- another panel!
- HHR 2006 tranmission fluid fill plug, need to unescrew
- Adding factory remote start, 2009-2011
- 07 Panel engine options.
- OEM roof rail cross bars
- reverse gear won't engage(dont move in reverse always in foward)
- ???plastic tail light access planels
- p0014 code
- 2011 hhr lt
- rear hatch
- Front end frustration
- Wheel Speed Sensor
- Good ground spot under dash?
- Can I fit a 6ft. Aluminum ladder in the back?
- 2010 HHR SS Turbo OR supercharger?
- New dashcam, wiring question!
- Steering wheel alignment; i-shaft snapped
- 2008 LS engine ID code?
- 2008 hhr
- Opinions about HHR usage
- Side rail install?? Should i?
- Ignition switch wiring diagram/pinout/color code.
- Cell phone holder
- Parts or Junkyard?
- TCM problem?
- Slight Wobble after hitting small bumps or potholes.
- Seeking the flush mount roof spoiler
- Replace Serpentine belt
- Opinions on Years
- replace door blend AC actuator
- That time of the year again....
- looking for dome light
- Misfires and stalling
- need replace the FUEL line
- A/C Drain
- Esc
- Cooling Fan and Fuel Pump never turn off - 2009 HHR
- Coolant temp….
- Water pump
- engine harness
- Dash Cluster
- Driver window won't go down
- Orange turn indicator light on drivers side is on all the time
- 2006 HHR Wipers only work on high
- New cooling fan has metal clips? Do I leave them alone?
- Steering
- Air intake for 2011 2.4 ltr
- 2008 Chevy HHR SS - check engine code P0101
- Admin Please
- Balance Shaft Sprocket Removal
- HHR Gauge cluster issues
- Loss of acceleration, won't start
- HHR Head Light replacement
- looking for spray painting WA913L Sunburst Orange Metallic
- Engine identification , 2.2 vs 2.4?
- 2010 Cobalt SS BCM3 fuse blows
- Door Ajar Indicator
- How would you install a wall in passenger hhr
- Part Needed: Front Bumper Valance (Deflector)
- Mysterious Device
- Won’t turn over
- Custom HHR truck
- Class 3 trailer hitch receiver?
- HHR Replacement
- Mods?
- 08 HHR 2.2l won't start
- 2010 HHR roof rack
- Rocker panel
- Deal
- intake cam shaft senor
- Big cooling system brought my operating temps 25*C lower than stock
- need wiring help
- 06 gray interior paint code
- Is it possible to install a turbocharger from the HHR SS model to the LS one?
- Car stereo
- enter into cooling mode
- woohoo! HHR number five!
- Drivers seat foam
- 710 still good
- Getting engine code P0010 and service traction
- New owner
- water in passenger side
- Losing oil
- Thermostat housing removal
- Sudden drop in mpg
- American Classic Whitewalls
- Got HHR problem
- 2009 HHR cup holder compatibility?
- Thermostat housing question
- Spare tire area Q
- Need advice
- Passenger Inside Door Handle
- Car won't move
- Headlight problems
- Vent actuator, but which 1
- Service Manuals on Ebay
- 2006 hhr CRAZY
- SeatBelt Dilemma
- Rear hatch struts
- push button start
- Engines and Towing
- ? Tie rods
- Has anyone swapped lead acid for an AGM battery?
- Chevy HHR AC Condensor Replacement
- 2008 hard shift code P0752
- can't find my old post??
- Knock sensor
- Butyl patch
- Help...
- Hhr code po756
- Stop lights
- 08-10 fuel pump removal
- Brake upgrade
- VERY hard brake pedal while running
- Doors
- Rear disk brakes
- Found previous Facebook post for my car
- Odd trans issue
- Headlight bulbs?
- Get window to work
- rpm increase in neutral gear(manual shift)
- Service Manual
- HHR will not warm up
- Click click click
- Heater issues
- 2011 chevy hhr.
- Control arm
- Front Axle nut size
- 08 HHR cranks but does not start
- Engine stuttering
- So cold...
- P0172 & P0561 after 30 second idle
- 2007 HHR Transmission issues
- Knocking? from engine bay
- Window Cleaning
- Looking to ground Digital antenna
- 5-spd manual guys: How many miles on your original clutch?
- Heated seats mod ?
- Headlights not working after stereo and sub install
- Need a name for my 2007
- Radiator Cap hard to come off and put on???
- HHR Newbie, Common questions
- Steering wheel rattle
- HHR Inside door handle in metal?
- Flooded HHR
- Indicator lights
- needed a laugh..
- 06 HHR Engine Noise - Anyone know what this is?
- Ground for trailer wiring
- Interior Light
- Poor FM reception with engine running.
- 07 Auto Lock not working
- 2008 HHR Special Edition Suspension
- first gear don't engage first time, but the second to the first yes
- Foolish to give up Honda for HHR?
- Which hhr ss to get?
- Rear hatch
- P1516 & p2101 2007 hhr lt
- Gas key
- Hhr help
- Trys to start when I hook up battery...
- Rim Question
- up date
- Thoughts on HHR 'Value'
- Sunroof issues
- WTB HHR door
- 2009 Chevrolet HHR LT 57,400 1 owner regularly maintained.
- Dimming
- replace normal bulb for Halogen
- rear bumper cover 2009 HHR SS
- Battery on 2008
- Power steering motor?
- WTB - AC Heater Climate Control Unit Switch w Heated Seat
- Where to get a crank pulley key?
- LCA Bolt
- P062f
- This years local car show, juat a few pics
- fog light button Illumination
- Hitch adapter and riser?
- lobotomy
- Brake booster/master cylinder
- Getting back in the saddle
- heating on the high only work
- Damaged remote control & tire pressure module
- Chinese parts Spammer
- Rcdlr 2006-2008
- Should I clean this sludge or leave ot alone
- GM trailer hitch
- Time for a smoke test - P0171 issue
- Broken guide bolt
- Bobby Bode Racing
- code P0449 HHR 2006 Evaporative Emission Control System
