View Full Version : 2.2L Performance Tech
- 2.2 or 2.4? how can ya tell?
- Flex Fuel Engine problems
- 2.2 engine swap interchangeable
- P0171- This one is a head scratcher
- 08 2.2 throttle body compatibility question
- Lost Compression
- 06 hhr lt 2.2
- P0172, P0446, P0300 Try to diagnose.
- More power
- P0016 - changed 2 years ago
- 2.2 interchange
- Drive cycle (EVAP)
- Coolant level
- 2007 LT Throttle Body Relearn Process
- 2007 HHR LT Installed Cat Back Exhaust and Got a Bunch Of Codes
- 2010 Crankshaft reluctor wheel
- 11 2.2L Head internals
- engine vibration at idle
- 2.2L Atuomatic Transmission Swap
- 2.2 Front main seal replaced with engine in car?
- 2006 hhr
- Ecotec Engine Build
- Turbocharging Hhr 2.2L
- Aluminum Coolant Tube
- Lack of steering signal in 1st cylinder injector
- Exhaust Manifold problem
- EGR Valve
- Rough Idle and car dies
- Additives?
- 2008 chevy hhr engine compatibility
- Won't start
- Flex fuel question
- 2011 HHR motor swap
- Did I just grenade my motor?
- No tach
- Advice on timing
- Exhaust Pipe Flange Studs
- Installing Timing Chain
- Seats From 2007 into a 2009
- Last 1 of 2...
- HELP!! Blowing Fuses!!
- Reduced engine power? Tried alot
- 2011 Chevy HHR (Just got supercharger kit)
- O2 sensor question
- Timing Chain Tensioner
- zzp 2.2 turbo clearance problems?
- 2011 hhr 2.2
- 2008 HHR 2.2. Suddenly having multuple codes and profirmance issues.
- ACDelco VS Motorad-not all thermostats created equal
- Finally can afford to tune, but can’t find one
- Gibson cat-back Exhaust
- code PO326
- Temp guage working after clearing ECT code
- Single Cylinder Misfire - intake valve spring
- Replaced Cat now I have Code issues
- Need help with engine swap !
- Timing question
- Running Rich
- using too much oil
- 2.2 motor question
- I have an 06 hhr 2.2 swapped motor from hhr 07
- The Front End Clunk...
- 2.2 crankshaft interchange
- 08 hhr LT 2.2 compatible cars???
- Supercharger kit from ZZP
- Moving the second O2 sensor, will it cure the P0420 code?
- Cost to rebuild 2.2 liter flex fuel engine
- 2.2 Oil catch can, more of cleaning up then performance!
- Stuck in park/but not stuck in park
- metal shavings in oil filter
- Codes C0292 P0013 P0014 HELPPPPP
- 08 hhr 2.2, new head/camshaft problem. 07 cobalt head
- 07 HHR Engine limited power check engine light on
- Got the dreaded P0016 code
- Need advice: HHR 2006 with codes PO135, PO700 and UO140
- Engine power reduced
- Blue smoke
- P0171 lean bank 1
- Flat rate
- Engine swap
- Codes P0016, P0101, P0102, P0113
- Help
- 170,000 miles
- beefing it up.. 2.2
- HHR tune available?
- How to get a Trifecta Tune
- Headers, downpipe and catback.
- Car won't start
- 2010 2.2 horsepower rating
- P0300
- 2006 Chevy HHR
- Fuel additives
- replacing chain tensioner
- Header blowing gaskets
- Looking for help with intake and turbo
- Replacing manifolds ?
- 2006 2.2 brain storming..HP Tuners and turbo
- Newbie here with exhaust question.
- 2.2 1200hp
- p0016 trouble code
- Hard to start in the AM.
- Serpentine belt keeps falling
- starting out
- 0-60 with Trifecta Tune
- Is a 2.2 to 2.4 engine swap possible
- Miss on acceleration
- header question
- 2.0 Intake
- is there any measurable increase in torque/hp with a cold air intake?
- Radiator Cap
- oil in coolant
- exhaust diameters
- 2.2 stock tune file
- 400 or 200 cell high flow cat??
- Hhr wont start....low ding sound
- gibson exhaust
- Air Intake Hose/GMPP Intake
- how to turbo
- check eng light
- Sprockets timing marks on opposite sides...WTH
- supercharger install
- HPTuner
- Possible Solution to Code P0303
- Replacing my engine
- Is there a PCV valve on a 2006 2.2L?
- G Force Performance Chip for 2.2 L
- Frustrated with cam sensor
- Spark plugs
- need a little help wit P0068
- Exhaust
- Using Air raid CAI kit with 2.2 Manual trans
- 2011 Chevy HHR (ZZP S/C kit)
- Cam Button Sensor??
- Reworked my Cold air intake
- P codes and anger
- Stumble & Cough
- 2.2 to 2.4 adapter
- Vids of When Shagy 06 had a S/C- So much FUN
- Turbo kit or S/C Kit?
- 2.2 white Panel turned into a TVS SS
- Porting a 2.2 head?
- Trifecta Tune
- Summit Racing intake manifold
- Balance Shaft Delete..?
- '07 stock LS upgrades?
- 2010 Panel Supercharging 5 Speed LAP 2.2
- battery change...
- Supercharging a 2.2
- HHR Turbocharger
- Secret Weapon short air intake.....
- 2.2L with 75% Trifecta Tune V/S Stock 2.4L .. Both Auto trans.
- 2.2L Exhaust And Intake
- Exhaust options??
- another tuning question
- Air intake hose
- Exhaust Cut-out for 2.2
- Stock SS turbo kit on 2.2
- Need a second Tune
- ZZP downpipe question
- o2 sensor 2008 2.2L
- New stuff makes a difference.
- HHR 2.2 down pipe no cat
- cgs intake
- towing with 2.2ltr
- Boost gauges
- Sway bars..
- HHR Chip
- Whizzing noise
- ZZ Performance Long Tube Header install 2009 HHR 2.2L
- H Pipe a 2.2?
- Turbo
- 2.2 Headers/pipe
- Performance novice with a shiny new toy!
- Supercharging 2009 HHR 2.2L VVT
- 2.2 hp question
- ion - hhr
- trifecta on a 2.2
- supercharger project
- leaking struts?
- Jim W
- Idling Issues with supercharger
- Trifecta vs HPT
- exhaust help
- Cat-back
- TTR aluminum intake manifold
- GFORCE Chip
- HPTuners question
- Cool Air Intakes for The HHR 2.2L
- Hahn turbo
- Anyone use this!!
- Newbie with a couple questions
- Spectre Intakes???
- Cant find parts anywhere!
- New Owner Needs Directions
- Removing 2 Cat??
- comp cam question
- GMPP vs Magnaflow
- Which oem dp will fit 2.2 lap
- My Experience with CAI
- Will the cobalt as supercharger setup fit on hhr 2.2l
- Quick question..on 2 mods (intake and exhaust)
- Do they work????
- Question about the Trifecta Tune/Any Tune?
- NA/Cammed Build
- Question help please adding a turbo
- Tune??
- Supercharge the HHR?
- Info Regaurding Air intakes.
- Etest coming up soon in ontario
- Cold air intake HELP!
- Chip
- $200 what do ya think....?
- Mods while engine out
- Exhaust
- What next
- Add a supercharger or turbo to chevy hhr
- Need for acceleration for highway
- 2.2 Tune ?'s
- Weapon R Intake for a 2.2
- GForce Chips
- Trifecta tune
- LSJ Axles on a 2.2L ?
- Airaid Cold Air
- 2.2 verses 2.4
- 87 or 93?
- Cold Air Intakes
- ZZP on 2.2???
- Sprint Booster
- Tuning the 2.2
- MAF sensor mount
- 2011panel, best bang for the buck mods
- Thrush Turbo Mufffler?
- KOOL VUE POLISHED MUFFLER W/ Resinator
- cherrybomb
- CGS intake filter
- Air filter
- Trifecta Tune soon..
- Swap the stock MAFS for an aftermarket one?
- Weapon intake
- Gmpp
- 2.2 trifecta tune
- Pipe size
- airraid hose line
- trifecta tune
- 2010 L61 and SAI?
- performance chip(or lack thereof!)
- Super Charger swap from SS Cobalt to Newer HHR
- i wanna go fast
- Quick Custom Intake
- AGS intake update
