View Full Version : Maintenance and Upkeep
- GM Forward thinking Belt tensioners
- Front end fixes
- Replacing Headlights
- SS thermostat replacement
- Codes P0010, P0011, C342D, P0013, P0014
- HHR Under hood Fuse box/junction box (electrical issues)
- Polyurethane Bushings: Yes or No
- New battery, won't start
- windshield washer tank location
- Defroster and AC Out
- Part identification question
- Wheel Bearings & Struts- How Long Should They Last?
- Rear license plate mount.
- List of Gaskets
- Should it stay or should it go?
- Looking for an engine
- custom rear springs
- lower control arm and hub bearing replacement
- 2.2 l or 2.4 l
- 2010 HHR SS transmission filler
- Gear shift knob
- MPG after light "tune-up"?
- My 2008 is showing its age
- What spark plug to use? brand and part number
- Throttle body cleaning
- HELP! How do I tighten my negative terminal clamp???
- Sunroof closing issues
- light bulb
- Cooling fan not working
- 14,000 miles per quart
- Charge battery from jump posts?
- Lower control arm, rear bushing bolt/pin
- Hatch won't lock
- Slowing down noise believe to be in front?
- Need an exhaust system-- suggestions?
- Esc light on and esc off.
- Windshield leaks from top on one side
- P0014,0016,0017 AND 0128...HELP Needed.
- Brake pad, rotor, and sensor replacement cost
- Coolant flat line
- 2009 HHR Drivers Power Window not working
- HHR SS (2010, 152K Miles) - Engine Growling Noise - Linked to RPMs
- door stop strap
- driver lock and windows don't work
- CEL p0014 is back after being replaced 14 months ago 2011 , 2.2 150k miles
- What PM would you do @ 155K?
- Coolant issue.
- Yay or Nay? Change Transmission Fluid?
- How much timing chain play is too much?
- Water pump or engine swap?
- Engine Tune Up Questions
- Cooling Issue
- Need expert advice
- Can't pinpoint what sounds like a bearing issue!
- Question for those who have replaced timing chain
- Where Is Fuel Pump Pass Through Connector
- Strut anguish.
- Oil leak (I think) on driver side.
- 2009 HHR Headlight bulb replacement
- Cam Positioning Sensors ?
- HELP - spark plug torque setting and other tips?
- Front Wiper Blade Length
- Horn replacement ideas
- Starter interchange
- Coil Springs
- Rear control arm bushings
- Odyssey ODP-AGM96R (96R-600)
- Moonroof low on leading edge
- Engine flush product ?
- Coolant
- Bumper Paint Failure
- Rear Hatch Panel ?
- Stalls and Speedometer spikes
- License Plate Bulb ?
- Need some input: ways to keep coolant cool
- Difficult shifting after clutch replaced. What's going on?
- (another) ABS Question
- Wiring diagram for blend door
- Exhaust manifold/catalytic converter issue
- How to find Battery Drain?
- New to working on a HHR and got a fairly big question.
- Cleaning all l the grounds
- Rear wheel bearing life expectancy
- P0011 , 2011 , 2.2 engine
- Transmission fluid change
- Left brake light not working... it's not the bulb
- Transmission jumping?
- Service Traction control and ESC light on the dash
- Trouble with Body Control madual how to test
- Wiper Transmission ?
- Got a grocery list of repairs today
- Coolant Flush
- 2.2 resonator can size?
- Bypass the pass seat switch?
- A What are they called ?
- Question relative to transmission fluid
- Window not working
- The lock indicator light is on.
- best oil filter to buy
- Did Headlight Restore
- PSA: Check your air filter often!
- TPMS Sensor Replacement
- 2.4 timing chain interval?
- E85 fuel and now it idles rough at start up
- AC/Heat Circulation light
- Frozen doors
- Maintenance Parts Suggestion
- 2011 starting to get loud, options?
- Fuel Range Issues
- Where to get HHR GM OEM suspension parts
- Consensus on when to change the oil
- Shift boot for 5sp
- Aftermarket headlight advice
- Gas cap
- Code ?
- Cat back Exhaust Replacement Questions
- Plastic Fastener Kit
- Oil fill cap
- Spark Plug Boots?
- Need help with paint color
- Turn signals
- Body repair , any procedure how to fix?
- Valve train noise!
- Shock absorber question
- Anyone ever experience this code?
- Window Wind Deflectors- CHROME
- Rattle in front end -- like someone got married and strung cans to the car
- original oil ?
- OBD ll Scanner ?
- Maintenance Costs at 140k Miles
- Window Switches in driver door
- 2006 HHR - replace brake fluid level sensor
- Turn signal
- Wanting to change belt 2007 hhr
- need info about exhaust pipe + rust remover and polisher
- Timing Chain Kit
- Cleaning interior + fragrance that smells like brand new interior
- Help identifying this thing on the valve cover
- How to get the smoothest possible ride (raising suspension?)
- massive dirt underneath the HHR
- Oil type
- Catalytic convertor replacement, is it welded to the Resonator pipe???
- Hood supports
- Cleaning Headlights ?
- 2006 HHR - Fuel Level Fluctuates
- Motor mounts
- Battery mystery
- Reading the oil dipstick
- LED rear brake turn bulb recommendations
- Jack and Lug wrench
- Panel side doors
- Dome light bulbs
- 06-07 injector failure, TSB vs alternative method of repair research article
- Replace Rear Main Seal
- A/C clutch suddenly stopped engaging; no prior problem
- Fuel line help?
- Strange Issues, Any ideas
- Inside door handle replaced
- 08' HHR Flex pipe replacement
- Where to lift,or position jack pad?
- 2010 shifter light
- Engine replacement
- Side door too far forward
- Exhaust hanger question?
- Unknown Oil Leak
- Proper Oil
- Latch mechanism
- Rubber Door Seals
- Fog Light
- Sunroof adjustments
- Key Fob
- Old Cabin Air Filter
- oil leak on passenger side
- Cleaning cooked on grease.
- Torque to yield V. tighten to angle
- Cleaning chrome wheels ...
- What Are These Wires For?
- 2007 Chevy HHR LT - Windshield Leak?
- Brake shoe advice
- KYB Shocks/Struts Warranty
- 02 sensors! again!
- Sunroof rear drains
- Rear Door Protective Stickers
- Battery Brand Opinions/Experience
- Blend door knocking
- Wiper blades 2008 HHR SS
- AutoLift 3000 - any one use
- Diagnose help
- CV joint as an alternative to a CV Axle
- Hub: w/ABS to car without ABS.
- oil change won't fix it i told him LOL ,,,,
- Driving without intake hose
- Coolant Flush - Splash Shield and Drain Valve (petc0ck)
- Brake Fluid warning
- Air filter cross over
- How to restore headlights
- Check engine light
- Sway bar bushings
- Map lights not working
- Chrome Cleaner
- '06 hhr leaking rear washer fluid internally; d/c'd drain tubing flooding floorboards
- Remove engine air filter cover
- 150,000 miles on the HHR
- Snow and ice tires
- Oil Change to Synthetic or Semi Synthetic?
- Different axle seals on left than right
- Engine Light - P0014 and P0017
- 9 year old air filter?
- strut mount bearing size?
- What the Funk??? Try an Ozone Generator
- 2.2 check engine light
- 2010 Chevy HHR LS Trouble lights
- heater fan motor
- Front end rattle finally fixed!
- Rocker panel
- Tune up ?
- 2.4 Timing Chain
- key entry sounds alarm
- Crank Pulley Torque Question 2.2L VVT
- ATF
- Rear center brake light 08 SS
- Body control module
- Tie rod toe ajustment
- Brake shoes
- Remote Start and duplicate key
- Driver side window 2011 HHR
- 2008 2.4L Oil Filler Tube Part Number
- Ac leak
- Yes, yes you can
- Tpms issue
- Timing chain
- Creaking
- Charcoal Canister Seal
- panel dashboard door button
- balance shaft chain
- hood grommet/bumper
- ac compressor clutch
- Brakes and abs question
- Lower control arm question
- Dead Battery? Rear Lift Release Lever - DENIED
- HHR Transmission question
- Oil video/Something to think about
- How to jump start an HHR?
- Seat occupancy sensor/mat
- Emergency flasher clip
- -50F RV antifreeze
- Sunroof wind filter
- headlight bulb alignment
- Steering wheel coil clockspring
- Windshield washer tubing
