- 2010 Auto Trans Issue
- Engine to trans mounting bolts
- Turbo not turboing and tons of trans codes!
- Source for end cap inside bellhousing of Getrag F23 manual transmission
- What’s this part??
- Wire crushed
- Swapping the automatic for a 5speed manual
- Swap to manual shift
- Transmission Bearing Noise.
- trans swap 2008 to 2010
- Passenger side axle seal leaking, again!
- Transmission swap problem
- Passenger side output shaft seal Automatic transmission
- Automatic transmission shift anomalies
- HHR SS F40 swap help
- 2010 HHR SS Stage 1, 5MT. Won't go in to 5th
- I hit a deer, now im getting no crank from the starter
- Problem with daughter's HHR
- Can you identify this transmission part? Please help!
- Please Help!! How can I bleed my clutch on 2006 Chevy HHR
- The Hippo does not go forward (but!... goes backwards).
- Transmission cooler line seals
- Trans hard shifting
- Difference between early/late '08 transmission
- Who makes the best replacement CV axles?
- trans harness's
- code p722
- shifter control housing
- 1-2 solenoid
- Talk me out of driving off a cliff. 1-2 shift issues.
- question about limp home and stuff
- Shifter Swap
- Simple question.
- traction control light keeps going on & off
- 2007 chevy hhr
- P0741 Torque Converter stuck off code after replacing solenoids
- Drive train noise
- Won't start after shift solenoid replaced
- Can't Access Upper Transmission mount bolts
- Transmission Magnet covered in goo
- Replacement Trans: First Time Start Up
- 4t45e transmission has spare plug?
- Problem with automatic transmission
- Hhr shut off
- 2011 HHR auto hard shift issues at times.
- Vibration at 30 Mph
- Where to Get a Good Used 4T45E Trans?
- Removing the Auto Trans
- Tcm issues?
- Differences between 06-07 and 08-11 auto Transmission/Engine
- 2006 HHR stopped shifting to 3rd
- shifting problem chev hhr lt
- Auto Trans Check Plug - Where Is It?
- auto trans
- adjusting apply/release torque converter
- The automatic to manual swap thread
- Aftermarket clutch recommendations
- Service traction control light
- Clutch master issues
- Engine swapped no start
- CV shaft inner joint issue
- No Reverse
- TCC solinoid issue
- R&R Manual Transmission
- Clutch swap
- Shift solenoid replacement.
- Newbie transmission question
- Trans swap
- Transmission issues...
- Tow Hitch
- transmission oil cooler replaced
- 2006 - HHR 2.4L with P0700 and P0741 code
- What does this bolt do???
- Slave cylinder bolts
- Shift Solenoid
- manual trans shifter cable ends
- Transmission Turbine Shaft O-Ring
- Axle Seals in Transaxle
- HHR trans interchange ?
- TCM Fitment question
- Need help getting EBCM working after body swap
- 2010 LT Axle Spindle Size
- Trans-go shift kit
- Transmission output shaft seal issue
- VIN Decoder
- Traction Control
- Transmission Cooler Lines
- Clutch Life Expectancy
- Traction control off light
- Transmission
- Cutting a Top access Fuel Pump hatch
- How to verify my transmission
- Right side stub shaft came out while driving
- Clutch fluid leak at junction to transmission
- What is the problem?
- CV Axle or not?
- Second Gear on Manual
- What trans do I have?
- new clutch needed
- Shift knob options.
- Which CV Axle brand to use?
- Output shaft/inner CV joint
- Can I replace a clutch without a hoist?
- 2010 HHR automatic Tranny problem
- 08 HHR SS CV Axle
- How to remove stuck intermediate shaft from cv shaft
- hard shifting problems
- Has anyone replaced a shift solenoid?
- Transmission issue??
- 2010 HHR Code Issues
- TC "BUG" Traction turns off
- Play in transmission output
- 64 error codes
- 08 HHR 2.2L Auto Trans Problems
- Clutch pedal bumper
- Rear hub
- Dome light and rear view mirror not working
- stick shift
- 3.91-3.63
- P0842 Transmission Fluid Pressure Switch
- HHR Making a New Noise
- 06hhr shift problems
- Hard shift, traction control service on, no solenoid codes
- 40 mph RPM bounce
- trans axle output shaft seal replacement
- tranny
- Auto Trans exploded in 09 2LT Replace OEM or Upgrade?
- Clutch Upgrade Kit
- P0700 and P0741
- Transmission slips only when cold
- Intermitant transmission slip??
- Sensor?
- Auto Transmission fluid issues
- help with check engin light and traction control
- manual transmission lubrication
- Need a new drive shaft
- Cv shaft at transmission is not tight??
- Surges At Low Speeds
- Transmission
- Transmissiom fill amount ????
- Automatic shifter interlock solenoid?
- manual clutch
- Drivetrain vibration
- no reverse
- starting problems
- ESC and Traction problems
- ESC light issue
- 2008 solenoid B stuck open code for transmission
- trans problem?
- Half shaft Seal
- Hard shift 3-4th between 2500-3300 rpm.
- F40 LSD 6-speed HHR SS
- plugs
- Drive belt tensioner replacement
- Starter? Maybe...?
- Throttle body problem
- Dead (clutch) pedal?- no leaks
- Trans Flush
- F23 (non-SS) Front Manual Transmission Mount Polyurethane Bushing Install
- Some Fun for the Day, No Clutch Driving Home from Parkland
- Transmission shifting issues
- clutch pedal to floor and fluid leak
- Auto tranny leak
- Clutch catches just as you let off?
- Manual control of automatic transmission
- 07 LT with 51756 miles Trans Issue...
- Manual Trans lubricants and lube changes
- Transmission temp sensor?
- Transmission thumping/jerking
- Dexron III or Dexron VI?
- Help! Trans issues!
- Transmission swap
- Manual Trans Axle removal
- Traction control?
- Dead Transmission?
- Transmission Cooler line seals
- Traction control
- Heat Issues
- Overdrive, Engages and disengages too frequently!
- custom old school shifter
- Turbo Tech F35 tranny mount
- Wheel Bearings
- transmission removal
- Axle Seal Replacement procedure from shop manual
- Rumble strip noise in front
- Abrupt shifting
- Key Will not turn off.. shifter or ign switch???
- Installed the B&M Shift Improver.......
- dead pedal syndrome
- Front Hub replacement covered under PT warranty?
- Front Hub Axle Nut
- Whatcha call it?
- Need your help !
- Overdrive not engaging
- What did I just get from Powell Racing?
- SS clutch
- Where to bleed clutch
- HHR Front Wheel Bearing Assembly
- Kevlar or Ceramic Clutch for Daily Driver
- 2.2L Clutch needing replaced
- Vibration
- Transmission/ engine mount question
- TTR trans mount question..
- It seems to float
- Auto SS Axle Shafts
- TWM Short-Shifter Install Tip. Important.
- 2008 2.0 SS Trasmission Issue
- Do I need to upgrade tranny and/or clutch?
- Input on Polly urethane tranny inserts
- Slight L/R axle shaft freeplay noise
- A VERY VERY Serious Transmission for Serious tuners plus MORE!!!!:
- Traction Control Light on
- Shift Indicator Light
- Would you like cheese with that WHINE????
- Noise when going faster than 35 mph
- Synthetic Trans Fluid (Auto)
- Zzp built trans?
- Is this the correct Output Shaft Seal?
- Will this hurt my trans?
- 2006-07 Different CV Axles???
- 06 HHR Wheel Bearing (THANKS FOR THE HELP)
- Today we discovered 'I'
- speed reduction in 'Drive'?
- 2007 hhr automatic transmission
- Ky clutch is ordered!
- Broken Shift Cable
- Twm shifter installed!
- Do I "NEED" the special 32mm to remove the oil filter?
- KY stg3 install review and first inpression
- Replacing automatic transmission pan
- Possible Transmission Failure
- Its clutch time!
- Traction Bars, Parts List & Install
- 69,000 miles and synchros gone
- What If, the Crossmember was two Piece ?
- Automatic gear selection question
- 6 speed auto?
- Axel Seal
- Clutch replace
- Traction control
- Inner Axle Splines?
- Do I need seal protectors for new axles?
- SS Manual Clunking
- My first post and it's long
- Lower/rear mount.
- TTR Upper Engine Mount
- Built auto tranny?
- Water dripping down on passenger side floor ....not from rain
- Can I adjust my clutch takeup point?
- New Forum
