- Starts without a key.
- Fuel Line Leak Update: NHTSA Contacted Me
- 2007 Chevy HHR LT - Recalls
- GM ignition switch settlement
- 2009-2010 airbag recall
- Broken Door Handles
- Any Recall on HHR Steel Fuel Line
- ignition recall again
- ignition recall
- recall for latch on storage bin in center area of dashboard
- 2009 shifter recall recalled
- brake master cyl & rotors
- Recall?
- 5 years and looks like more recalls are due
- Heading one off at the pass..
- In for recall repair.
- Airbag harness recall
- Reimbursement of ignition change
- Did GM Pay Pre-recall Repairs?
- Key Stuck In Ignition Warrenty Extention - Not a recall #14632
- Ignition Recall done, now ignition binds and won't turn.
- Ign key and door key different after recall
- GM recall kit:(pictures)
- Does GM even know IF your recall parts are ordered ?
- Employee Pricing for Ignition Switch Recall
- LINK TO #teamrecall shirts
- Are You Losing Money? Thanks A lot Recall!
- getting that fixed today
- Less than 20% of ignition switches have been replaced
- GM recall question
- problems after recall revisited.
- Bad Power Steering Motor?
- Recall site
- How many keys will I receive after recall repair
- how many of you registered for the class action lawsuit re power steering &ign switch
- Recall
- Anyone with problems with SS(power upgrades) ignition recall ?
- Link to check your recall status
- power steering 2010
- problems AFTER ignition switch replacement?
- Diagram of recall parts:ignition switch,key cylinder
- why no recall on hhr 2011 pwr string pump
- Was there a recall on the airbag system?
- HHR Recall for Ignition
- I'm New to the Forum...
- ignition switch cylinder key
- went to the dealer for the recall...
- Sheesh
- Ignition recall
- Check for recalls and report safty defects like airbag system
- New GM Recall Forum...
- Ignition Switch Recall Key Question
- NOW there's a power steering recall on GM vehicles?! No, it's a warranty extension!
- GM NEEDS to put a recall on the vacuum pump assist problem!
- GM Ignition Recall Extended to All HHR's 2006-2011 UPDATED!!!
- GM Recalling 2006-2008 HHR's
