boost
Old 08-26-2014, 10:42 PM
tmc6382@hotmail.com's Avatar
boost
I have an 08 hhr ss on a normal I'm pushing 25 to 26 psi boost quickly and holding at that. But here in the past couple of days at any point time I can get on it full throttle and I will only hit 20 psi and hold until 4500 revs and then slowly hit 26 psi boost by red line. What could cause this and how do I fix it without spending a lot of money
tmc6382@hotmail.com is offline
Old 08-26-2014, 11:00 PM
25-26 is not normal boost numbers for a stock SS. You either have the GMTU or an aftermarket tune. Other possibility is an inaccurate boost gauge.
Until you "fill in the blanks" so to speak on what mods you have, then it's hard to just guess.
Also stating your mileage and what transmission you have would help.
firemangeorge is offline
Old 08-26-2014, 11:01 PM
Talk to the guy who tuned it.
SS fan is offline
Old 08-27-2014, 07:46 AM
I'm not sure what upgrades it's got I bought it about 2 months ago. It has 89k miles and it's a manual transmission. I know it's tuned 26 psi is not stock
Old 08-27-2014, 07:47 AM
Other than the tune everything else looks stock under the hood
Old 08-27-2014, 01:54 PM
badassbowtie's Avatar
My guess is that you have a slight boost leak?
badassbowtie is offline
Old 08-31-2014, 02:06 PM
asanti's Avatar
If you're tuned to 25-26 psi on the stock KO4 turbo, get it DETUNED and run a max psi of 23-24 psi, especially if still on stock intercooler + piping. Beyond that the turbo's being overworked and is pushing heated air into the intake manifold.
Later
Allex
asanti is offline
Old 09-22-2014, 09:26 PM
Ok I figured it out I have had it looked at and I have the trifecta tune and everytime I would get low boost I would have my cruise control button on mostly from my wife driving the car so basically when the cruise button is on it turns the tune off and it runs at 20 psi and with the cruise button off it runs at 25 psi
Old 09-22-2014, 11:56 PM
XtremeSS's Avatar
The best problem you could have lol. You can have the tune revised by trifecta if you don't like the way the car is running, or you upgrade parts. There is always HP tuners software as well.
XtremeSS is offline
foxtrotraptor
45
08-10-2013 06:00 AM
redss87
04-17-2013 02:42 PM
Nazgul 9
12-01-2012 04:10 PM
ssdivin
04-26-2011 06:55 PM
ecopower02
2.2L Performance Tech
27
08-14-2006 09:09 AM
Quick Reply: boost
