Boost issues
Boost issues
08 HHR SS, 139,000 mi. When my car is off, my boost gauge reads 25 vac. When I turn it on it stays around that at idle. The needle goes up when I give it gas, but even at WOT it doesn't go higher than about 2 vac. Any ideas?
FYI - your post in the FAQ for SS has been moved to a more appropriate section - ie: here. Your duplicate post has been removed - and your two other posts (all the same) have been deleted. Please do not post the same question in multiple places!!!
Be aware that the forums here are not monitored on a minute to minute basis, so a reply to your post may take an hour or two, or longer.
One of the experienced SS owners will hopefully give a reply and give you a hand with this.
to the forums!! What the gauge reads when the engine is off is meaningless. But the fact that you're not building boost pressure is a problem. You need to get the OBD2 codes read and post just the alphanumeric part here, i.e. P1244 or whatever, not the description, which can be misleading. You probably have a problem with the wastegate or bypass valve.
LuckyLadySD
06-12-2014 02:09 AM
