Boost issues
Old 10-18-2016, 12:27 AM
Parker2636's Avatar
Boost issues
08 HHR SS, 139,000 mi. When my car is off, my boost gauge reads 25 vac. When I turn it on it stays around that at idle. The needle goes up when I give it gas, but even at WOT it doesn't go higher than about 2 vac. Any ideas?
Parker2636 is offline
Old 10-18-2016, 02:28 AM
FYI - your post in the FAQ for SS has been moved to a more appropriate section - ie: here. Your duplicate post has been removed - and your two other posts (all the same) have been deleted. Please do not post the same question in multiple places!!!
Be aware that the forums here are not monitored on a minute to minute basis, so a reply to your post may take an hour or two, or longer.
One of the experienced SS owners will hopefully give a reply and give you a hand with this.
whopper is offline
Old 10-18-2016, 03:09 AM
to the forums!! What the gauge reads when the engine is off is meaningless. But the fact that you're not building boost pressure is a problem. You need to get the OBD2 codes read and post just the alphanumeric part here, i.e. P1244 or whatever, not the description, which can be misleading. You probably have a problem with the wastegate or bypass valve.
RJ_RS_SS_350 is offline
Old 10-18-2016, 03:30 AM
thanks for jumping in there RJ - I'm not up on turbos at all. Thanks man.
whopper is offline
Old 10-18-2016, 07:12 AM
No problem, whopper, I like to help when I can.
Old 10-19-2016, 02:30 PM
Unfortunately he continued to post the same question yet again - a total of 6 times by my count - banned for 4 days.
whopper is offline
Old 10-19-2016, 06:53 PM
Maybe he doesn't know how to find his threads or posts.
Old 10-19-2016, 07:13 PM
Technical Moderator
Both whopper and I sent him links.
donbrew is offline
87ninefiveone
09-30-2016 11:32 AM
LuckyLadySD
06-12-2014 02:09 AM
Rainman
12-02-2010 03:27 AM
ecopower02
2.2L Performance Tech
27
08-14-2006 09:09 AM
Quick Reply: Boost issues
