HVAC System
No power to the controls but you replaced all these parts anyway ? Maybe I'm misreading your posts.
First thing to check is for power. If you have none, then relays and fuses. And, you do realize the power for the system goes through the BCM.
All of these been checked?
Inside fuse box: fuse #10,#16. Relay #30
Engine comp box: fuse #4, #6
