Wheels and tires
Old 03-10-2017, 09:58 PM
Brianordodin's Avatar
Wheels and tires
I was trying to figure out the largest Wheel and Tire setup I could put under one without a bunch of work I was reading one thread on here it said that someone put twenties on there HHR is that correct
Brianordodin is offline
Old 03-10-2017, 10:18 PM
Not the size of the rim that counts but how tall the tire is.
26.3 inches is about the tallest that will fit. Any taller and they would hit/rub the lower strut perch.
Fwiw. Running 20 inch rims would require a very short sidewall tire. That would give you a very rough ride. If it's a daily driver car, 20's wouldn't be a good choice.
firemangeorge is online now
Old 03-10-2017, 10:43 PM
Hi Brian, to the forums!!
Here is a chart of overall tire diameters that may help you find that perfect size!
http://www.importtire.com/itphotos/doc-od-ref.pdf
RJ_RS_SS_350 is offline
Old 03-10-2017, 10:51 PM
Technical Moderator
The absolute physical limiting factor is interference with the lower spring perch on the front struts.
There are also safety concerns using any size other than came from the factory.
If somebody said they are running them on their car, I would tend to believe it, but I also believe the moon is made of bleu cheese.
donbrew is offline
Old 03-11-2017, 06:09 AM
Welcome to the site, I thought the moon was Swiss cheese? But , yeah, nothing over 26.3 inches tall
Oldblue is online now
Old 03-13-2017, 02:09 PM
jeffs396's Avatar
jeffs396 is offline
Old 03-13-2017, 02:14 PM
Nice, 20's!
Hmm I need taller tires, my 215/55R16's don't measure up!
Attached Thumbnails Wheels and tires-20007-hhr-replacement-lower-springs-001.jpg
Old 03-31-2017, 01:55 PM
MGMsHHR's Avatar
these are not real big but they are perfect and they are cheaper than 20's......
check these out https://www.chevyhhr.net/forums/clas...ls-sale-58672/
Last edited by RJ_RS_SS_350; 03-31-2017 at 02:07 PM. Reason: Provided link to classified ad
MGMsHHR is offline
