after market wheels and TPMS
Old 08-10-2008, 01:20 PM
spotty's Avatar
Cool after market wheels and TPMS
Hello:
Does anyone in here know for sure whether the sensors on the LS factory steel wheels can be carried over to aftermarket wheels that are made for the HHR?
I am getting conflicting stories on this. pepboys says depends (?---not the diaper, I hope)----the HHR probably needs new sensors for the wheels. NTB says no problem. The internet is not conclusive (discount tire and tire rack---although they seem to infer no problem).
Pls chime in if you have had thsi done and what was your experience?
thx
spotty is offline
Old 08-10-2008, 03:31 PM
Digital_Rapture's Avatar
Originally Posted by spotty
Hello:
thx
They can be carried over no problem! I had them pull the ones out of the stock wheels and placed them in my diablo's. I'm gonig to get a second set of the monitors to throw back in the stock wheels this fall. I'd rather have a second set instead of having to break down and carry around 8 pieces instead of 4. The only problem I had was the genious at the shop who did my wheels had a brain cramp and forgot to put one of the sensors in. No biggie though. They placed it in and I just had to recalibrate the sensors. This "How to" can be found in your owners manual. You will need your OEM fob for this.
Digital_Rapture is offline
Old 08-10-2008, 06:36 PM
spotty's Avatar
thx for your help my friend
spotty is offline
Old 08-11-2008, 10:04 AM
spotty's Avatar
Another question
Does anyone else know what type of wheel----chrome, painted, aluminum---is best in weather like PA.'s. I want only one set of wheels to worry about.
thx
spotty is offline
Old 08-11-2008, 11:25 AM
08HHRPA's Avatar
Spotty, I hate to tell ya, but most people in the rust belt states switch the wheels out for the season if they're running custom wheels.
08HHRPA is offline
Old 08-11-2008, 03:41 PM
spotty's Avatar
Doug:
I see your point--but--I had a jeep with painted tan aluminum wheels for 9 years and I never took them off for winter---they looked like new when I reluctantly traded it.
My wife has a 2003 monte---likewise---the wheels have not been switched out for winter and they are also like new.
Of course---both are garaged----don't know if that makes the difference. That is why those damn moons from Mikes were so neat---looked great--easy to switch out---but---alas---they liked to travel!
peace
spotty is offline
Old 05-12-2011, 08:09 PM
showcook's Avatar
I bought tires and rims from the tire rack with plans to install the original TPMS in the new wheels. I can get the sensors out by removing the screw but i cannot get the valve stems out. I need the stems so i can screw the TPMS back into the valve stem. Can i just buy the valve stems? Any insight on this would be appreciated. :)
showcook is offline
Old 05-12-2011, 08:36 PM
ChevyMgr's Avatar
You have to dismount or at least break the bead to remove the sensor. the valve stem is part of the sensor. Are the wheels and tires coming to you already mounted? If not whoever mounts them can swap the sensors.
ChevyMgr is offline
Old 05-13-2011, 01:01 AM
prod's Avatar
The rubber stems are available separately, and come with the screw. It is quite difficult to get the old ones out without damaging them as the base of the stem is quite a bit larger than the hole in the wheel.
prod is offline
rocdoc2112
Tires & Wheels
11-26-2011 04:43 AM
BlackknighT
08-19-2011 07:15 PM
Sheverlay
Tires & Wheels
11-05-2009 08:01 PM
ecaryn
Tires & Wheels
08-06-2009 04:02 PM
lvrpool32
07-14-2009 05:58 AM
Quick Reply: after market wheels and TPMS
