lug nuts dont seem to stay tight
Old 06-11-2015, 04:57 PM
chella55's Avatar
I was washing my hhr, noticed couldnt fun finger down in lug hole to clean it well, so checked lug nut and it was loose. Tightened it some, then checked others ...found they all were lose some and some would tighten then go cycle into lose feel again.
I actually called to set up service and guy answering phone couldnt even tell me whats up...set up oil change and going to talk to mechanic when I go.
Geeze can the wheel fall off?
chella55 is offline
Old 06-11-2015, 05:12 PM
Technical Moderator
Do you have plastic wheel covers? If yes, those nuts hold the the covers on, they screw onto the actual lug nuts.
donbrew is offline
Old 06-11-2015, 05:46 PM
chella55's Avatar
Thank you
Yes it is plastic covets and I thought how flimsy lug nuts. Thank you very much I'm 56 female and I do good around the house like celing fans and stuff but other than cleaning and polish the car and air in tires it's not my cup of tea. Again thank you!
chella55 is offline
Old 06-11-2015, 06:23 PM
The metal lug nuts are to be hand torqued, to 100 lbs.
Oldblue is offline
ruger1v
01-09-2013 04:02 PM
bigjacksauto
Maintenance and Upkeep
12
06-14-2012 08:53 PM
garagebuilt
05-25-2009 09:23 AM
rockNroad
2.4L Performance Tech
17
04-15-2007 01:17 PM
Quick Reply: lug nuts dont seem to stay tight
