Tpms
Tpms
I havw a 08 panel which I will be putting aftermarket wheels on in the spring. I will more than likely buy new tires also ,my question is I will need to replace the tire presure sensor also and I found some on e-bay # 15922396 for 59.99 Anybody have experiance with this monitor?? Good or bad??
Thanks,Dave
Thanks,Dave
I replaced the stock wheels on my 08 in the first 100 miles. I got the wheels and tires and sensors from Tire Rack and the sensors have performed perfectly. Pricing is on their site. You can move your present sensors but I understand from other comments there are wheels that require special sensors to fit correctly.
PS I highly recommend Tire Rack. The wheels and tires with senors were under 1K$ at my door. They send everything you need including lug nuts.
