Blacked out on a budget
Old 08-10-2019, 01:52 PM
WoodysMobile's Avatar
Got used wheel covers for a Malibu cut out the center cap painter flat black.
What do you think? Got the covers from pick and pull on sale day two broken. Cut out the center part with a cutoff wheel.
$10 for 4 caps, and a can of flat black rustoleum from Ace for $6 and my efforts.
WoodysMobile is offline
Old 08-10-2019, 02:56 PM
If that's a HHR, the tires look way too small. There's too much clearance between the fenderwell and the tire.
firemangeorge is offline
Old 08-10-2019, 03:57 PM
Actually looks about the size of the temporary spare...
Greybeard999 is offline
Old 08-10-2019, 04:40 PM
They are the stock sized tires for the '08 LS 215/55R16 The ground to fender well measurement (center) is 28.5" in back (pictured) and 27" front..Too high?
Monroe shocks and struts (Kit) all around no rear sway bar.
It did have extra load tires in the rear when I purchased. Perhaps the previous owner added spring in order to haul weight?
Old 08-10-2019, 09:37 PM
I thought you had it on jack stands , Time for a set of Canuck Motorsports springs and a TTR rear sway bar.
Oldblue is offline
Old 08-10-2019, 09:54 PM
I thought same thing as well. Creative making those center caps work on those rims.
sleeper is offline
Old 08-10-2019, 10:03 PM
The stickers peeled off over the winter
Much better then Toyota caps in Oldblue’s winter rims
Oldblue is offline
Old 08-11-2019, 09:14 PM
sleeper is offline
xzombiex66
08-21-2011 08:54 PM
mobster wagon
05-06-2008 03:04 PM
tjplogg
03-22-2008 07:01 PM
914nickd
19
09-01-2007 06:05 PM
DARK AGE 53
20
09-20-2006 05:19 PM
Quick Reply: Blacked out on a budget
