Tire Pressure Monitoring FAQ's
#71
#72
Two sets of wheels
I have a set of steel rims with studded winter tires and the original tire pressure sensors are mounted into this set. I also have a set of alloy rims with summer tires and no sensors. Can I get a second set of sensors and teach them and somehow switch between the two sets easily?
#75
#77
They make what they call "cloneable" sensors now. You can buy a set of them to stick into your second set of wheels. Then when you swap there is no need to reprogram. There will be the initial need to clone the new sensors though. Most tire stores can do this for you.
I use them when swapping from my street tires to track tires on another car.
#79
#80
I have been looking at a set of new wheels for my 2008 HHR LS I really want the They look Great with the matching Baby Moon hub caps. In the information tab, it says the wheels are Not TPMS compatable. has anyone used these wheels? If so how did you get around the TPMS problem. I have seen these, or wheels that look like these wheels on an HHR, and they look great.
