Tire Size
You have to run the same size tires on the front and back. The ABS speed sensors will go bonkers if you run different sizes.
Fwiw. That 205/65/16 would be too tall to fit on the front. Also not sure why you would want to use a skinnier tire than the stock recommended size.
Moved to it's own thread.
The height and width are the important parts.
Tire Size Calculator - Discount Tire Direct
