Tire size caculator | odometer | speedometer
Is your odometer/speedometer off after changing tire or wheel size?
Taken from miata.net web site:
"Use the calculator to see what happens to your speedometer reading when you change the size of your tires and wheels."
http://www.miata.net/garage/tirecalc.html
Thanks to T 20 for posting this link in another thread. I felt it worthy of a sticky in the this section.
NOTE: You need a Java enabled browser to view the graphic calculator.
Thanks to Sleeper, here is one for one if your browser is not Java enabled:
http://www.discounttire.com/dtcs/infoTireMath.dos
Cool Sindy, This is one of the ones I use: NO JAVA needed... simple
And you can compare any speed you select to see the difference..
Here is another site I found to help calculate wheel sizes.
http://www.kouki.co.uk/utilities/vis...ize-calculator
Another one, this one will allow you to compare more than just 2 sizes at the same time.
http://www.1010tires.com/TireSizeCal...?action=submit
I'm really curious as to why most of the online Wheel and Tire stores recommend such a narrow tire. According to all the website calculators, when going up to a 17" rim the closest diameter fit for my 06 LT with 16" rims and 215 55 16 tires would actually be 235 45 17s. Most of these sites are only recommending I use either 215 or 225 at the widest. Most of the aftermarket rims I am looking at are at least 7.5" wide which should not cause a problem with fitment. Can anyone tell me why I should not go to a 235 on new tires? Any feedback would be helpful. Thanks.
Try the link I posted above & plug in the rim width of your choice.
B1GP1MP1N-
If you've used this link, I hope you scrolled down after to see all the details of each tire choice & comparison etc..
http://www.rimsntires.com/rt_specs.jsp
