Wheel torque
Old 01-07-2010, 05:44 PM
Lethal Tendencies's Avatar
Wheel torque
I maybe picking up a set of 17" aluminum wheels tomorrow.Is there any specified torque in foot pounds for installing them?
Lethal Tendencies is offline
Old 01-07-2010, 06:50 PM
esmarkey's Avatar
TORQUE TO 100FT/LBS THEN CHECK AGAIN AFTER 100 MILES ON NEW WHEELS.
esmarkey is offline
Old 01-07-2010, 08:55 PM
Thanks
Old 01-07-2010, 11:37 PM
Go up in steps torqing the wheels ie: 25/50/75 & 100, doing the star pattern.
& if your rotors, drums or new rims have any crub or rust, clean em good for a good flat surface.
(but I'm sure you already know this stuff)..
sleeper is offline
Old 01-08-2010, 08:03 AM
esmarkey's Avatar
Originally Posted by SSguy
Go up in steps torquing the wheels ie: 25/50/75 & 100, doing the star pattern.
Actually that's good advice to anyone putting on any wheel, new or old, more brake rotor warping is caused by unevenly torquing wheels than anything else. If you use the "star" pattern and slowly build up to max torque you lessen the chances that you will get that dreaded brake vibration that is often blamed on cheap rotors. Not that cheap rotors isn't the culprit sometimes.
esmarkey is offline
metalhead52
04-18-2015 07:53 PM
ucadam
10-24-2013 02:30 PM
8t7vette
08-02-2010 02:09 PM
millerrdjr
05-10-2008 08:50 AM
Krusty
04-07-2008 02:39 PM
Quick Reply: Wheel torque
