Keyfob cold solder repair
Old Mar 25, 2009 | 07:33 AM
Jeff®'s Avatar
My wife's keyfob wasn't working so I figured I change the battery. Step one is to pry the clam shell apart.
And much to my surprise (NOT) the battery holder was suffering from the often reported bad solder connections.
OK, fire up the soldering iron.
There are three solder points to repair. The center one is surface mount, and the two outer ones have feed-through holes. Make sure to fully seat the battery holder down in them.
After repairing my wife's keyfob, I decided to check mine. Unbelievable lack of quality control on these things. While the electrical connection had not (yet) broken, the battery clip wasn't even level with the PCB. GM should really be ashamed of themselves for this part.
Old Mar 25, 2009 | 07:40 AM
hhrcrafty's Avatar
GM doesn't make this part, they buy them from a supplier. Crack open fobs from other manufacturers and they'll be much the same. You could have just taken it back to the dealer and they would have given you a new fob, just like every other manufacturer.
Old Mar 25, 2009 | 07:58 AM
ChevyMgr's Avatar
Jeff, I thought this was a nice HOW TO, so I moved it to that forum. Thanks for the detailed explanation of the repair.
Old Mar 25, 2009 | 07:59 AM
Lucky's Avatar
thanks for the how to great pics
Old Mar 25, 2009 | 08:07 AM
Jeff®'s Avatar
Yes, I know they get it from a supplier, but ultimately they are responsible for what they deliver to the customer. In any case, my soldering skills are as good as anyone's although I seldom do it anymore. I fear going to the dealer would be a waste of valuable time and I would just as likely get another one doomed to fail. Ain't gonna fail now.
Old Mar 26, 2009 | 09:16 AM
SLVR FOX's Avatar
same thing happened to my fob, but the board was cracked. $65 for a new fob and $30 to program it. i only paid the programing cause my samesman is awesome and gave me the fob for free.
if my new does this ill be solderng it.
Old Mar 27, 2009 | 02:15 PM
Sno White's Avatar
I also liked the post.
Not all of us have easy access to the dealer. My dealer is 5 hours away and my ability to do simple repairs is paramount to both my life's enjoyment and time. Warranty is not the deciding factor to me - time, convenience and money is. Good Jeff!
I do agree with the general statement about the poor construction of FOBs. I have had solder connection problems with whatever vehicle/alarm FOB I have had.
Old Mar 31, 2009 | 10:52 AM
RStruthers's Avatar
Key fob
I found the same problem and fixed it myself also. Just about bought a new one, thankfully I didn't. So many of these problems are poor quality control. Now I'm having a squeal in the fan motor under the dash. Has any one gotten in to that?
Old Mar 31, 2009 | 01:13 PM
esmarkey's Avatar
Jeff, this is a great write up with great pics. Very helpful to anyone who wants to do the repair themselves.
Also, we now all know that the replacement battery is a CR2032
Old Mar 31, 2009 | 03:15 PM
SICKS.OH's Avatar
this awesome!
mine recently quit working and i have strong feeling this will fix it!
