2009 HHR SS One Owner
For Sale2009 Chevrolet HHR
Description:
The good - One owner from new 09 HHR SS 5 speed 139k with perf option including gauge, LSD and Brembos. Only changes from stock is the GM stage 1 upgrade. Fairly recent front brakes (rotors, calipers, pads) and new rears (all parts). Interior is clean and minimal wear. A/C still works fine.
The bad - Sunroof only tilts, does not slide. Clutch pedal does not always return completely, seems to be outside temp dependent. Maybe a slave problem? There is a slight noise which could be from the turbo or an exhaust leak more noticeable on initial startup. One front wheel bearing is starting to make a little noise.
The ugly - Trans has a slight bit of play in it like there is too much backlash. Could be a problem with the crush sleeve. Also the front bumper cover was repainted due to a hit of an object on the highway and has many stone chips now. Rest of body is decent with a small dent on drivers rear. It also has a class II modified hitch so that it comes out just under the bumper cover without it being cut.
I was going to do a refresh on the car but the Mrs sent me in another direction. Price is $4000, non negotiable. I also have a lot of new parts I had already purchased for an extra $500. Suspension, timing and balance chains, water pump, flywheel, front rotors, spare rebuilt front calipers and more. Also a second set of wheels that are black plasti dipped with well worn snow tires. Those go with the parts. Probably over $1k worth of parts. Contact by PM.
