the *new* HHR Marketplace Private party sales only. Poster must be the one offering the item(s). No third party sales. For Sale items MUST include a price in first post of thread. Off topic post(s) not directly related to the purchase of the item and threads with no price will be removed. Pictures posted that are not the actual item being sold are not allowed.
Fully Machined Zero Mile 2.2 Ecotec Engine
For Sale
Engine - Complete
  • Engine - Complete - Fully Machined Zero Mile 2.2 Ecotec Engine - Used - 2006 Any Make All Models - Las Vegas, NV 89129, United States
    Expired
    Expired
    Expired
    Expired
    Expired
    Expired
  • Price
    $1,500
  • Location Las Vegas, NV, 89129, USA
  • Condition Used
  • Compatibility
Make Model Year
Any Make Any Model 2006
Description:
This is a fully machined engine, not a used junkyard unit with unknown history. It will fit several year make and models of GM vehicles.
2002-2005 Cavalier
2005-2006 Cobalt
2006 HHR
2004-2006 Malibu
2002-2004 Alero
2002-2005 Grand Am
2002-2005 Sunfire
2005-2006 Pursuit/G5
2000-2004 Saturn L Series
2003-2006 Saturn Ion
2002-2007 Saturn Vue
If your vehicle uses a crankshaft position sensor like the one in the last picture, this engine will work for you.
Block machined
4 new pistons
Rods machined
Cylinder head: Valve job, valves, valve stem seals, milled, valve guides replaced
Crankshaft ground and polished
Valve cover Gasket
Timing cover gasket
Timing set: Chain, guides, gears, tensioner
Balance Shafts timing set: chain, gears, guides, tensioner
Water pump
Front crankshaft seal
Rear main seal
Head gasket
Main bearings
Rod bearings
Piston rings
Installation is available.
$1500
I only accept cash
Price assumes on if you have a core to offer in exchange. If you do; does it smoke? Knock? seized? hole in block?
