Steering Rack, Tie Rod Ends
For SaleSteering/Suspension
Description:
A used Rack and pinion steering gear
a2 brand new tie rod ends.
Over a year ago I ordered most of the front end parts for the 2011 HHR including tie rod ends, strut assemblies hubs, brake pads and rotors, stabilizer links, ball joints and the solid type control arm bushings, all Moog
It was suggested to me to go ahead and replace the R&P since they supposedly wear out, so I got a new GM Delco Rack.
It came complete with tie rod ends.
Upon removing the existing rack, I discovered it not to be worn at all, but went ahead and put the new rack in since I could not return it anyway after such a long time period.
I did use the Moog tie rod ends in place of the new Delco ones.
So I am offering the good rack and both new tie rod ends for $0.00 and whoever must only pay for the shipping.
It is all packaged in the original box I received the rack in .
I will deliver it to either a UPS or FedEX store.
I will not handle any shipping costs, you must do that all over the phone at the closest store.
Package size is 6x9x61 and weight is 20 lbs
Here is a link to the closest UPS store
https://locations.theupsstore.com/fl...paign=Listings
Here is closest FedEx
https://local.fedex.com/en-us/fl/for...PLCOPYANDPRINT
