22lbs on stock tune?
Old Apr 23, 2012 | 09:52 AM
JAXFL_SS's Avatar
I threw another P0101 code this morning on the way to work. Plugged in my OBDII scanner and reset it. Restarted the car and after that, I had 20-22lbs of boost all the way to work. Me thinks my analog gauge has been corrupted....
I'll see what it does when I go out at lunch.
Old Apr 23, 2012 | 10:28 AM
RobSSTurbo's Avatar
Is stuck at 22psi or You will hit 22 psi?
Old Apr 23, 2012 | 11:14 AM
bigjacksauto's Avatar
hmm maybe you found a Zero cost mod LOL
Old Apr 23, 2012 | 12:19 PM
rallycobalt06's Avatar
not sure about your 22psi situation BUT i've heard that not being tuned for an intake will cause you to throw a code.
Old Apr 23, 2012 | 01:24 PM
RobSSTurbo's Avatar
Po101 is a maf code so your trim are probably little off with that zzp intake.
Old Apr 23, 2012 | 01:28 PM
Breadfan's Avatar
Nooo, don't mention the CAI!
Old Apr 23, 2012 | 03:03 PM
Premiere07's Avatar
Originally Posted by breadfan
nooo, don't mention the cai!
ah hahaha
Old Apr 23, 2012 | 03:51 PM
JAXFL_SS's Avatar
haha. thanks Rally, but I am not opening that can of worms again. tune will be coming. ordering the HP suite on Friday.
either way, it seems to have "resolved" itself. It's back to its standard 15-16lbs when I last took it out at lunch.
Old Apr 23, 2012 | 03:53 PM
Breadfan's Avatar
Well, that it then, you just had to treat it nice and tell it you had a present for it.
Old Apr 23, 2012 | 08:28 PM
it's almost a weekly event on this site. someone has an issue, the common factors between y'all is some sort of intake and lack of custom tune.
maybe we should put a massive neon flashing sign on the top of every page.
