Any performance gain IC pipe
Old Oct 11, 2015 | 04:49 AM
Cat Man HHR's Avatar
I would like to know if installing an aftermarket hot side IC pipe showed any improvement in performance and/or mpg.
Old Oct 11, 2015 | 10:43 AM
Not without a change in your tune..However the metal ones wont blow up and damage your hood.......:)
Old Oct 11, 2015 | 02:32 PM
Are you going to say the increase of volume/flow of the pipe will effect a tune that much? I have a Trifecta tune that can be reprogrammed. Boost now is 24 psi and have no issues with the plastic pipe so far.
Old Oct 12, 2015 | 08:46 AM
DrLoch's Avatar
I have found that changing the hot side pipe from the OEM plastic to a round aftermarket does make a difference.
I have also found that it doesn't effect the tune in any way. If you move the MAF and depending on where you put it or change the size of the tube the MAF is mounted in you will have to do a re-tune for the frequency/airflow change.
Old Oct 13, 2015 | 04:32 PM
jas89tta's Avatar
I've been running the stock IC pipes with a Trifecta tune since 2009 with no problems about to hit 124k and so far so good :)
Old Oct 13, 2015 | 06:49 PM
In what way? Does the turbo spool up faster?
Old Oct 14, 2015 | 07:14 AM
DrLoch's Avatar
Yes, the boost comes up quicker.
hhrumadbruh
Jun 7, 2013 08:58 PM
Littlemanhhr
2.4L Performance Tech
23
Oct 1, 2009 11:37 PM
badboy69
Jan 9, 2009 11:16 AM
Don Juan
2.2L Performance Tech
10
Mar 13, 2008 06:28 AM
