bog and boost problem
Old May 6, 2019 | 09:41 AM
1965ss's Avatar
boost is not consistent floor it you can get variable boost anywhere from 8psi to 24psi. it also will bog pretty bad. once in awhile i will get p2187 check engine code lean at idle. anyuone have an idea i think possible the secondary fuel pump is weak . this car has a stage 2 gm performance .
Old May 6, 2019 | 10:00 AM
You could do a search on that code P2187. There are several threads about it.
This one had an easy fix:https://www.chevyhhr.net/forums/ss-s...ss-auto-50932/
Posting the year, mileage and what transmission you have would help. Also, how long you've owned it.
FYI. Nothing called a GM stage 2 that I've heard of. Guess you mean the GM Turbo upgrade (GMTU) also called a Stage 1 kit.
If you have that, with the old style crimp connections, take a look at the lower Tmap wiring. Corroded wire crimps or them hitting against the AC compressor are known to happen and cause performance/boost issues.
Old May 6, 2019 | 12:49 PM
Cat Man HHR's Avatar
Thanks George.
How many times this info isn't posted before explaining the problems.
Old May 6, 2019 | 03:03 PM
Blue_SS's Avatar
Pressure side leak would also give similar results, but it should be more consistently weak and boggy. You probably have your answer already...
Old May 6, 2019 | 03:44 PM
The information in his page shows 2008 SS
Steve Gilbert
Nov 22, 2016 02:16 PM
87ninefiveone
Sep 30, 2016 11:32 AM
badassbowtie
Jan 12, 2013 03:18 PM
camaro98z28
Jun 10, 2010 02:48 PM
ts5p
Oct 6, 2008 02:47 PM
