Code P2090
I have an 08 with an LNF with 80K (the original engine was porous.) I had the intake and exhaust camshaft position actuator solenoid valves replaced, and those codes disappeared. I now get P2090. Any suggestions?
I have low boost pressure, about 6# also. |
Certain trouble codes will limit the boost to about 5 lbs. Fix the problem and/or clear the code and full boost should return.
It means that the exhaust CMP control signal is shorted to ground.
The OBD-CODES guy doesn't know what he is talking about. Another parts changer. |
Originally Posted by WemrMan
(Post 945162)
I have low boost pressure, about 6# also. What parts were used for replacement? Cheapie generics or OEM/AC Delco? P2090 Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit Low Voltage Possible defective exhaust solenoid or bad connector or wiring. |
I do think it’s a worn or stretched timing chain.
3 Attachment(s)
Evidently the shop manual is just wrong.
It says : If the circuit was open it would be P0013 If it was a bad signal it would be P0014 If it was the chain it would be P0017 P2090 is the cam position CONTROL circuit shorted to ground. It is a 2.0L only code Here is a pdf of the article, you can look for yourself via the FREE service manuals link in my sig. Attachment 49442 |
Very interesting!
Originally Posted by donbrew
(Post 945166)
https://cimg1.ibsrv.net/gimg/www.che...ed073f302f.png
First line for common causes, worn timing chain |
