DEI heat soak socks could cure your fuel issues
I'm always looking into new products and how they can maybe help issues on other rides , or maybe I just couldn't find the part for Cobalts , Ions , and HHR SS's, oh my!
These heat sink socks seem to be just the ticket for my turbo charged friends, check them out
DEI Introduces Jeep® Fuel Rail & Injector Cover Kit | Exhaust Header Wrap and Thermal Performance Products | Design Engineering, Inc.
Now I can read and do see this kit is for a Jeep but maybe there is a kit for the SS or this can be adapted or contact Design Engineering Inc for information from their tech guys
You'll notice a turbo blanket in their catalog,
http://designengineering.com/categor...insulation-kit
I wonder if that will help get a few more ponies or even just help in the under hood heat department.
Combined with this for the cold air pipe
https://www.designengineering.com//c...tube-cover-kit
To keep the air that just cooled in the inter-cooler stays cool
104 looks no comments or opinions? Nobody, not anybody?
I'm remembering back in the day , I ran my fuel line in a cool of copper tubing thru an ice chest in the back seat area and the chest full of ice to cool the fuel during a 1/4 mile run, in my 74 Valiant with a 440 stuffed in it, I don't recall any big advantage but it did run better and a little faster maybe 3 or 4 tenths of a second.
So I'm thinking keeping the fuel injectors insulated would maybe yield some advantage , like longer life as the plastic is shielded from the heat
http://www.designengineering.com///c...njector-covers
If the fuel rail is insulated then the fuel would be a little cooler and the engine could run more efficient
Anybody concur ?
Anybody concur ?
I'll comment.
I'd like to see comparisons on something like this, but my gut says it won't make much of an impact. Why? Because passing through fuel injector nozzles creates a mist which already cools the fuel right before ignition. Especially on a DI engine like the SS, where the pressure is higher. I'm not closed-minded, but I think this would help older, more traditional fuel setups more.
xzombiex66
Sep 29, 2008 10:00 PM
