Getting my intake and tb ported and polished.
Old Aug 2, 2012 | 05:53 PM
foolmoon_design's Avatar
A old high school buddy has a machine shop in Florida. I showed him the port pic. He said whatever you do do not try and clean that head while still on the car. One loose shaving and its done.
Old Aug 2, 2012 | 09:29 PM
RobSSTurbo's Avatar
I am not porting the head just the intake and the tb which are off the head. I am going to blow air through the intake when i get back to make sure. I am also going to clean the vavle with some tb cleaner and a rag. If there any lose stuff i going to hook up the shop vac and vacuum it out.
Old Aug 2, 2012 | 10:49 PM
Thats what I'm talking about, he advised against this. Sorry my fault shaving was the wrong word. But don't get me wrong, I'd still go ahead and clean it too. we take our chances.
Old Aug 7, 2012 | 08:07 PM
RobSSTurbo's Avatar
Its shipped out waiting for it come back i also order a new gasket and this:
http://www.performanceautowerks.com/...oducts_id=1880
cant wait to get it back!!
Old Aug 8, 2012 | 06:59 AM
Premiere07's Avatar
Just make sure you port match the spacer to the manifold, I assume they cut the spacer to the factory size, so their might be a lip that needs to be ground down after the porting.
Old Aug 8, 2012 | 08:58 AM
  #26
RobSSTurbo's Avatar
If that's case that somethin I can handle.
Old Aug 8, 2012 | 03:47 PM
  #27
AC66Bronco's Avatar
Good luck with this. Usually causes nothing but problems from what I have read.
Old Aug 9, 2012 | 12:54 AM
  #28
IgottaWoody's Avatar
Ive made a few spacers and carb adapters from phenolic ( working with airplanes made material acqusition easier) and never had a problem..just had to watch on the race car where tons of fuel was passing thru, that the phenolic didnt get saturated, so i just used a fuel resistant sealer in the bores. Manufactured ones shouldnt have this problem, especially in this case where theres only air involved. Dont really see the need for one on the throttle body as the spacers were used to keep the heat from the fuel. The air temp is going to be the same on either side..on the intake it might help keeping block heat off the manifold but then again ambient heat ( being close proximity to block) will affect it just the same unless you 'wrap' or otherwise coat the intake, Jet Coat comes to mind.
Since its pressurized air running thru there it might not really make much a difference as it moves fast and already heated......just some thoughts
And youll have to run 2 gaskets also(EITHER SIDE) which could cause some clearence/alignment problems in tight areas..
Old Aug 9, 2012 | 10:34 PM
  #29
RobSSTurbo's Avatar
I dont what your reading but I read alot of good stuff on this setup.
Old Oct 14, 2012 | 11:35 AM
  #30
Wolfblitz's Avatar
Still wondering how this all turned out.....
JJ's BLACK SS
Jan 27, 2011 12:02 PM
Black Beauty
Jul 31, 2007 12:54 AM
O6ChevyHHR
Apr 3, 2006 11:05 PM
