Chevy HHR Network
-   2.0L Performance Tech (https://www.chevyhhr.net/forums/2-0l-performance-tech-46/)
-   -   How To Verify Stage Upgrade? (https://www.chevyhhr.net/forums/2-0l-performance-tech-46/how-verify-stage-upgrade-35995/)
pnad Jun 3, 2011 09:40 AM
Hey guys, quick question about stage upgrade kits.
Looking at a used 08 SS. I noticed the upgrade sticker on the intake, part number 19212670.
It is an automatic. Is there easy way to verify the kit is still installed? Boost levels? Will I be able to see the 4pin MAP sensor easily?
Thanks
Vcode455 Jun 3, 2011 10:02 AM
You can tell by the seat of your pants if you've drive both stage and non-stage versions! :lol:
pitbull76 Jun 3, 2011 10:32 AM
Thanks
If it boosts anywhere near 20psi(or higher), it has the upgrade.
Victory Red SS Jun 3, 2011 10:33 AM
Thanks
You should see more than 15 psi on hard throttle. I see 20-23 usually. Also, open the hood and look at the upper sensor it's under a 3/8" black A/C line on the right hand side of the engine on top. It should only have one screw holding it down. The lower one is very hard to see.
pnad Jun 3, 2011 10:43 AM
Thanks guys
asanti Jun 3, 2011 10:53 AM
Adding to what V.R. SS said, the upper MAP sensor you can see will have a blue Bosch sticker on it and will have WHITE wires coming out of it. That's the dead giveaway.
Later
Allex
stephenm Jun 3, 2011 11:22 AM
Go by the upper map sensor and not the boost guage
raminator01 Jun 25, 2011 01:18 PM
would either one of you be able to provide a picture of this? i am wondering if my car has one as well.
asanti Jun 27, 2011 10:07 AM
It's a little hard to see here, but the upper sensor has the blue + white sticker, it's sitting under the vaccuum line at the bottom of the pic. For reference look just below the lower right bolt on the airbox and you'll kinda see it.
https://www.chevyhhr.net/gallery/fil...1/IMAG0366.jpg
