Hp tuner vs Trifecta
im sorry i should have been more clear. i was on my phone and wasnt paying that much attention to what the post was asking. the 3bar sensors will let the ecu see the higher boost levels correctly. what i was saying is they are not needed to achieve higher boost levels. the only way i would let those sensors touch my car is with the plug and play harnesses. i would rather have the ecu not be able to read the boost levels properly than have all the other bs issues that occur with the stage kit.
Just an FYI for everyone.
But this does keep it from rubbing, been running this for about a year, no rubbing the wires.
fcollazo60, give me a call, we can get together and see what's wrong with your SS. From what you're describing, your lower TMAP sensor's shot, or the wiring is frayed somwhere where it's shorting out intermittently. Send me a PM and we can get together sometime this weekend if you like.
Later
Allex
Later
Allex
jmm121783
2.0L Performance Tech
33
Oct 21, 2013 10:55 PM
