HPTuners VCM Suite
Old May 6, 2012 | 06:18 PM
  #71
JAXFL_SS's Avatar
RobSSTurbo...You ever get that pic of the Evap Solenoid?
Old May 7, 2012 | 08:29 AM
  #72
RobSSTurbo's Avatar
Here ya go. The red box is the sensor you unplug.
Old May 7, 2012 | 09:02 AM
  #73
JAXFL_SS's Avatar
Thanks man. That's what I thought it was, but I didn't want to go unplugging stuff without being sure.
Old May 21, 2012 | 01:39 AM
  #74
Breadfan's Avatar
I've roughed out the framework for a companion program for HPTuners that will read exported histos and allow tuning tables to be trended in various directions and limited in certain ways using calculations across multiple tables and give a snapshot of the expected result of the retune. The 'Load' button loads data into a spreadsheet. (working) The 'Show/Hide...' button allows the user to view and directly change loaded data. (working) 'Recalc' would reread the data from the spreadsheet and update the Snapshot in the main window. The power buttons would trend tables upward or downward. The % would represent the max move of data for any range that will allow a 100% move in data. (based on powerband) 'Commit...' would write changes to the histo files. 'Auto-limit' would prevent certain parameters from incrementing beyond a certain point. Obviously, there will be other things to add. If there is interest in this and I feel like I am having success with it, I'll open a new thread for it.
Last edited by Breadfan; May 21, 2012 at 01:42 AM. Reason: Correct info about power buttons
Old May 21, 2012 | 06:24 AM
  #75
foolmoon_design's Avatar
This has great potential. Especially, if you can gauge the outcome before applying to actual engine!
Old May 21, 2012 | 07:35 AM
  #76
JAXFL_SS's Avatar
Wow Rob! That's sweet! I look forward to seeing more of this...
Old May 21, 2012 | 09:14 AM
  #77
Breadfan's Avatar
Thank you for the kind feedback. Certainly, I should hope that it would give some idea of what to expect after flashing the car. Not sure how specific I can get with that at this stage. I'm aiming for a sort of code editor type of application. It could show visually when certain parameters are being/have been pushed out of proportion. It could give warnings/tips like 'Calibration is not for 2.5Bar' or 'Commanded boost is outside range of sensors' or 'Setting has reached maximum and is effectively limited vs other tables' or 'You'll blow your d@mn car up with those settings'. The powerband calculation could be made a configuration file so tuners could customize it to their specs or specific gearing.
Old May 21, 2012 | 12:53 PM
  #78
I love that last one... If you do this your car will explode!
or better yet.... I'm sorry Dave I can't do that - 2001
Old May 21, 2012 | 01:00 PM
  #79
Breadfan's Avatar
I could personalize it for you for when you use HPTuners, LOL. "foolmoon_design, you may experience an unscheduled, abrupt engine disassembly with current settings!". Kind of like the robot in the I, Robot movie, "You are experiencing a car accident".
Old May 21, 2012 | 01:13 PM
  #80
Turbo Hearse's Avatar
Nice Rob. Share that on the HPT forums and I'm sure you'll get all sorts of love.
