Intake headlight for relocated mafs??
Old Jan 12, 2013 | 06:12 PM
shortonmoney2's Avatar
Just a thought i have the full stage 3 zzp s256et already installed in my hhr which includes the relocted maf to the lower charge tube and the forward facing intake not far from where the breather hole on the stock box was i was thinking of making my own intake headlight (track use only) and running a tube to that location of the breather hole or cutting in a little more and running a tube from the opening straight beside the air cone to get cooler air straight into that beast of a turbo any thoughts anyone??
Old Jan 12, 2013 | 08:33 PM
Uhhhh. Go for it.
Old Jan 16, 2013 | 07:57 PM
XtremeSS's Avatar
If you remove the headlight, it should work beautifully.
Old Jan 16, 2013 | 08:11 PM
Some body has done that to the fog light, if I remember He liked it fine. Still had headlights to drive, a plus....
Old Jan 16, 2013 | 08:20 PM
skyline26's Avatar
or just drill a hole through your headlight
Old Jan 16, 2013 | 08:25 PM
skyline26's Avatar
or
Old Jan 16, 2013 | 08:41 PM
XtremeSS's Avatar
Lots of modification needed to make fog light induction practical. Not much room going from engine bay down to that area through fender. This what I mean...
Keep in mind, I have already removed some metal from this area. If you were to figure out a different way to brace the headlight area, then the existing brace you see could be removed to duct air from fog light area. The light in the pic is where the existing fender hole for intake is. Pictures are taken from this hole
Old Jan 16, 2013 | 09:09 PM
THE BATMAN's Avatar
Or the shortest most direct route .
Old Jan 16, 2013 | 09:33 PM
skyline26's Avatar
o my soo dirty :p
Old Jan 17, 2013 | 01:19 PM
The zzp intake comes up right beside the passenger side of the intake i was thinkin of cutting a hole run some flexible tubing from it thru where the stock box breather was and tight beside the cone
