K&N Air Filter
do i need a tune if i want to change to a K&N air filter? someone said i do and i just want to double check before i go get one.
thanks, mike |
No. This is also argued on the Cobalt forums. When I had a couple interceptor gauges in my SS, my numbers were all the same just after I changed my air intake to an Injen CAI-EXCEPT the MAF readings. They saw about 300cfm in increase. The computer was seeing the increase and was accounting for it properly. Some people throw a code when they change their intake. I never did. Car ran like a top. 1 mpg increase to boot.
Essentially, the change is not significant enough to need a programming. If you have OTHER mods, that's a totally different story. I see you have an exhaust. Have you removed your catalytic converter? Changed your DP diameter? Exhaust dia? etc. |
nope, i bought the car used and it already had the exhaust on it, i dont think anything else is done to the car. is there any advantage to changing the filter? will i get better mpg? will i hear the turbo a little more? what kind of change is 300cfm? i really want to learn about all these things, can you explain a little more?
Originally Posted by ChevyGuySS
(Post 573618)
thanks, mike https://www.chevyhhr.net/forums/2-0l-performance-tech-46/k-n-air-filter-27872/ It's a $45 gamble. Mine is on the wash room floor collecting dust until I get a custom tune. Good luck! |
Another one of these threads... to the people that say no have you seen what happens to your fuel trims with an aftermarket filter/intake without a tune??? thats all im gonna ask
(Post 573633)
Dave |
ya that helped, thank you for explaining it, what kind of BOV are you running? i kinda want to get one for mine but my buddy says i have to get a re-circulating one or something like that, what are your thoughts on that? i see you have one but you also have a automatic, would it be different?
I don't know about you but I drive down a lot of dirt roads.
Here's the crap I knocked out of my (original) stock air filter when I replaced it at ~61.5K miles last week. I knocked the dirt out and air hosed it last year and here's what was already in there this summer. https://www.chevyhhr.net/gallery/fil...FilterDirt.JPG My buddy has 30 years of experience as a full-time mechanic and is a serious performance enthusiast: 450HP 90's F250, 400+HP ST4, etc.. He agrees with me that if I had a KN much of this fine dirt would have gone through my engine. I have almost always upgraded to a KN immediately upon purchase in the past but road conditions require a stock replacement on my SS. BTW - Upon stock replacement I instantly noticed better performance & MPG YMMV I'd use a KN and make it work if I was staying on pavement. . |
i am staying on pavement, i just really want to hear that turbo but if i get an intake kit, im gonna have to spend a ton of money and get it tuned and everything, i just am trying to come up with a better solution
and that is a crazy amount of dirt, i have never seen anything like that before
