LNF Meaning
Old Apr 17, 2022 | 03:23 PM
PulpFriction's Avatar
Originally Posted by Oldblue
I’m in the midst of my engine builder putting together a 2.4 LE9 block with a 2.0 DI head and HPFP no turbo or blower, he wants to dyno that and decide from those numbers which way to go. It is for a sand buggy his son built .
I don’t really know what i’m talking about, but can’t think many good reasons to build a NA Ecotec other than a racing rule that bans forced induction. Even then, it seems just starting with a good LNF and removing the turbo would be more economical than a bottom-up build, which you need for 2.4 or you’ll just break it.
Probably not enough good used LNFs to go around though.
Old Apr 17, 2022 | 06:13 PM
He has a new LE9 2.4 short block and a new 2.0 LNF head, so he wants to try it out, see if it works, then add the M62 or the KO4 set up
Old Apr 18, 2022 | 11:23 AM
fastsuv's Avatar
I don’t really know what i’m talkinf about, but can’t think many good reasons to build a NA Ecotec other than a racing rule that bans forced induction. Even then, it seems just starting with a good LNF and removing the turbo would be more economical than a bottom-up build, which you need for 2.4 or you’ll just break it.
Typically, boosted engines have a lower static compression ratio to accommodate the turbo or supercharger.
I think the 2.2 and 2.4 have a compression ratio of 10.0:1, while the LNF has 9.2:1.
Removing the turbo on an LNF results in less power than the 2.4 since the compression ratio is lower.
Steve
Old Apr 18, 2022 | 11:29 AM
I agree, a 2.4 block with a DI 2.0 head won’t do much for power maybe better fuel mileage. John just wants to see what he can see on the dyno.
Old Apr 18, 2022 | 03:57 PM
Yeah, but direct injection has kinda been gradually breaking that rule, at least to a degree, right? Can’t get preignition if the fuel ain’t there yet. I don’t think higher CR is going to get you more horsepower in a turbo motor as much as it’ll get you better efficiency at low power.
But I can see your point. What would be the easiest way to increase the CR on an LNF? Wonder what happens when you put a Gen II L61 (2.2L) head on an LNF short block? Wonder where you’d go to find the volume of that head and LNF piston dome volume?
Old Apr 18, 2022 | 04:51 PM
A measurement of fluid in the cavity, how many cc’s of water to fill it level.
steveshow
2.0L Performance Tech
Jul 4, 2014 04:08 PM
longhornss
Oct 10, 2011 04:41 PM
JeramieJJ
Jul 19, 2011 11:13 AM
c2vette
19
Jan 29, 2009 08:34 PM
LT1GMC
Mar 10, 2008 08:13 PM
