LNF Meaning
Probably not enough good used LNFs to go around though.
I don’t really know what i’m talkinf about, but can’t think many good reasons to build a NA Ecotec other than a racing rule that bans forced induction. Even then, it seems just starting with a good LNF and removing the turbo would be more economical than a bottom-up build, which you need for 2.4 or you’ll just break it.
I think the 2.2 and 2.4 have a compression ratio of 10.0:1, while the LNF has 9.2:1.
Removing the turbo on an LNF results in less power than the 2.4 since the compression ratio is lower.
Steve
But I can see your point. What would be the easiest way to increase the CR on an LNF? Wonder what happens when you put a Gen II L61 (2.2L) head on an LNF short block? Wonder where you’d go to find the volume of that head and LNF piston dome volume?
