Questions related to the stage tune
Old Dec 23, 2008 | 09:49 PM
AaronSS's Avatar
Do any of you still have the stock boost gauge installed? If so what numbers are you showing?
Where does the stock gauge signal come from, exactly?
Old Dec 24, 2008 | 07:32 PM
bartSS's Avatar
Mine is showing 23 at most
Old Dec 25, 2008 | 06:03 AM
LT1GMC's Avatar
Mine is reading quite a bit higher than before, its been so cold here its hard to compare to normal, but at 0 F I was getting 7-8 max on the way to the dealer, and 17-18 coming back after the kit install. WAY more power however.
THe stock gauge is electronic, and gets its signal from the ECM, which gets its reading from the MAP sensor.
whopper
Nov 29, 2017 05:09 PM
Mowgli
2.0L Performance Tech
13
Jul 9, 2009 03:46 PM
tony326
Feb 12, 2009 08:47 PM
rommer
56
Nov 14, 2008 08:06 PM
