Seafoam ok ?
Old 11-13-2018, 05:40 AM
Lethal Tendencies's Avatar
Seafoam ok ?
I have this habit of dumping a can of seafoam in my gas tank every couple of months with my vehicles. This is my first car with direct injection and was wondering if it was ok to do this. I read the owners manual and it reccomends using some GM injector cleaner. Which is probably not readily available.
Lethal Tendencies is offline
Old 11-13-2018, 07:46 AM
Technical Moderator
OK if it makes you feel good.
The 2008 manual suggests using TOP TIER fuel that has injector cleaner in it. Most brands are TOP TIER these days including Costco. I don't see anything about adding cleaners.
donbrew is offline
Old 11-13-2018, 01:43 PM
X2 it’s up to you, I’ve not read anything about any benefits or otherwise.
Oldblue is offline
Old 11-13-2018, 08:31 PM
Well, with DI, it's not going to clean the valves. It's not going to clean the throttle body. Only thing it might help is the injectors.
RJ_RS_SS_350 is offline
Old 11-13-2018, 08:40 PM
tiapetra's Avatar
A lot of people swear by Seafoam, but in reality it is about 60% pale oil.
If you are so inclined, probably an easier and more fruitful regimen would be to use a tankful of Chevron gasoline once in a while.
It contains probably one of the most popular injector cleaners Techron.
tiapetra is offline
Old 11-14-2018, 05:36 AM
No Chevron stations by me. But I can buy techron at the local parts stores
Old 11-14-2018, 08:21 AM
Technical Moderator
TOP TIER certified fuels have all the injector cleaner you need.
donbrew is offline
Old 11-14-2018, 08:34 AM
DrLoch's Avatar
Bingo. That is the problem with DI motors that everyone is trying to solve. PCV and leaky intake valve seals are a major issue all the manufacturers are fighting to stop the coking of the intake valve issue.
Here is one idea, https://noln.net/2018/04/01/dual-por...engine-design/
DrLoch is offline
Old 11-17-2018, 08:36 AM
Casa Del Gatos's Avatar
Texaco also sells Chevron gas with Techron in it. Only two stations I buy from and I have NEVER had a fuel-related issue with any car.
As to cleaners, I was a big fan of Seafoam too, but knowing it can't clean DI systems as well, I switched to a better value product: Berryman B-12 Chemtool
Berryman B-12 Chemtool.
Bought by the case, it is less than $4 a can. I add a can every 5 tanks or so to in the SS and a smaller amount to all of my gas-powered devices occasionally.
It absolutely keeps the injectors clean and on some vehicles, that is noticeable. Made a huge difference in my gas-powered golf cart.
Casa Del Gatos is offline
badassbowtie
Maintenance and Upkeep
23
05-12-2013 02:01 PM
whitelightnin
05-11-2012 07:38 PM
rainmanva
7
02-20-2012 09:33 AM
KissMy08SS
7
01-17-2012 07:11 PM
catdaddy137
05-02-2009 09:04 AM
Quick Reply: Seafoam ok ?
